Sy0.5 10HP Syncsussion clone
Altitude909
Post by Altitude909 » Tue Oct 02, 2018 10:33 am
A faithful 1:1 recreation of a single channel of the Pearl Syncussion SY-1. The circuit use all modern versions of original parts (all the opamps are still in production!) and equivalent parts for out of production parts.
Features
10 HP
Current Draw: +12V 130 mA, -12V 20 mA
Output at eurorack levels
CV modulation of Decay Time
CV modulation of Filter Cutoff
CV Modulation of OSC pitch
OSC Mode can be selected by 0-5V CV OR can be advanced with a gate signal (2 modes)
Linear power supplies (NO switching nonsense)
Skiff Friendly (one PCB)
https://michigansynthworks.com/p/sy0-5- ... rum-module
PRICE: $325
User Guide: https://misw.us/SY0.5_UserGuide_Dec2018.pdf
Power: PSIpower so EITHER WAY, it makes no difference
Sweep/LFO functionality: I considered using 3 position switches for an "off" setting but it was really weird to use so "off" is with the modulation fader all the way down, same functionality.
CV Range: -10-10V. Faders act as a CV offset
Mode functionlity: There are two options for mode, one will advance the osc mode with a trigger in the direction it was last selected manually (up or down) or you can select the mode with a CV, 0-5V. You can toggle between these functions by long pressing both buttons
Power header orientation: This has Jim's PSIpower scheme so there is no polarity on the power header, either way.
Trimmers on the back: Per the original SY-1 the two OSCs are calibrated at 440 and 450 Hz and the CV tracking is calibrated over 3 octaves. The SY-1 has a bit of a quirk where the pitch slowly drifts down which makes calibrating this accurately a bit of a pain in the ass, Jon's solution was to ground out the S/H circuit before it connects to the modulation bus. This fixes the drift for calibration but on this device, that involves soldering a wire to an 0402 resistor so proceed with caution. I use a high accuracy PVR and good counter to calibrate so I can probably dial these in better than you can and I dont recommend messing with those two trimmers
Technically, the noise is supposed to be 2.5V peak to peak but I find its better to dial in by ear. This device has the correct noise circuit values per the service manual so the range is reasonable and right in the middle is a good spot where the amplitude matches the other modes volume wise.
The sense trimmer behaves just like the original and that circuit is unchanged. Sending a straight gate or trigger really wont have any effect, all positions will have a identical result but once you start sending it weird stuff, tweaking this will give you some more control. The SY-1 had a tom with a speaker in it as a trigger so its designed to take variable level triggers to add some expression, its not exactly a VCA but adding accent to the pulse levels does produce cool results by simulating "hit the drum harder". I'm working on a 4 channel piezo based drum pad to flesh this out further
kay_k
Post by kay_k » Tue Oct 02, 2018 10:41 am
DONE!
Paranormal Patroler
Post by Paranormal Patroler » Tue Oct 02, 2018 1:03 pm
:love:
Transistor
Post by Transistor » Tue Oct 02, 2018 1:12 pm
Broke at the moment but this one is on the very top of my list of next purchases, can’t wait! Will these also be available through dealers too?
kay_k
Post by kay_k » Tue Oct 02, 2018 1:15 pm
Transistor wrote:Broke at the moment but this one is on the very top of my list of next purchases, can’t wait! Will these also be available through dealers too?
I am broke too, but you gotta have priorities :twisted:
Modulus
Post by Modulus » Tue Oct 02, 2018 2:31 pm
I love that you can modulate the mode, sounds epic. :yay:
Altitude909
Post by Altitude909 » Tue Oct 02, 2018 5:04 pm
Yeah, Schneider's will have them
Transistor
Post by Transistor » Wed Oct 03, 2018 5:47 am
:tu:
kay_k
Post by kay_k » Wed Oct 03, 2018 5:48 am
I just paid ;)
What kind of caps will you use instead? just little rubber heads or none at all?
Always wanted a SY-1 (or clone) but a half SY1 module with CV over everything including Mode is even better!
please keep us posted how the production goes.
Altitude909
Post by Altitude909 » Wed Oct 03, 2018 8:04 am
kay_k wrote:I just paid ;)
The standard plastic E-Switch parts you see on everything (i.e. mutable).
uebl
Post by uebl » Wed Oct 03, 2018 9:18 am
Mhhh, intriguing.
brandonlogic
Post by brandonlogic » Tue Oct 16, 2018 9:00 am
i've never been interested or cared for the idea of a dedicated drum module until now.
Definitely going to pre order one (or two).
NS4W
Post by NS4W » Sun Oct 21, 2018 2:10 pm
Pre-orders closed?
tron23
Post by tron23 » Sun Oct 21, 2018 2:24 pm
Very happy to see that many Syncussion options in the wild these days.
:party:
Altitude909
Post by Altitude909 » Sun Oct 21, 2018 8:11 pm
NS4W wrote:Pre-orders closed?
No, I'll keep it open till I get a shipping notification from the fab
NS4W
Post by NS4W » Mon Oct 22, 2018 1:14 am
Altitude909 wrote: No, I'll keep it open till I get a shipping notification from the fab
Ok, ordered! (Enjoying your MI builds btw - top quality!)
naturarerum
Post by naturarerum » Mon Oct 22, 2018 7:57 am
holy crap... preordered
drowld
Post by drowld » Mon Oct 22, 2018 9:09 am
Also preordered 2.
:omg:
L.C.O.
Post by L.C.O. » Mon Oct 22, 2018 9:53 am
Does this module retain user settings through a power cycle?
Thank you.
Altitude909
Post by Altitude909 » Mon Oct 22, 2018 12:09 pm
L.C.O. wrote:Does this module retain user settings through a power cycle?
Thank you.
Just the OSC type. Everything is analog so nothing to save
brandonlogic
Post by brandonlogic » Thu Oct 25, 2018 7:32 pm
i cant contain my excitement for this thing. havnt been this hyped for a module in a while.
expected shipping for pre orders like 2 weeks away now?
PolarIceCaves
Post by PolarIceCaves » Thu Oct 25, 2018 8:34 pm
Hey Brandon I’m loving the enthusiasm toward this module
Could you tell me why you’re so excited for this? What am i missing?
Altitude909
Post by Altitude909 » Thu Oct 25, 2018 8:36 pm
brandonlogic wrote:i cant contain my excitement for this thing. havnt been this hyped for a module in a while.
hopefully, Panels came in already still waiting on boards. They were supposed to be done this week but sometimes it takes a bit longer than expected..
L.C.O.
Post by L.C.O. » Thu Oct 25, 2018 11:20 pm
Thank you.
I am afraid I don't understand.
What do you mean' that it remains or that it is lost after cycle?
Does the mode selection stay after power cycle?
Transistor
Post by Transistor » Fri Oct 26, 2018 12:16 am
L.C.O. wrote:
Thank you.
Think he meant there isn’t anything to be lost and OSC type is indeed selected through mode.
I’m super excited too, Pearl syncussion is awesome and having control over the tweakables... yumm
