disting mk3 startup sequence incorrect
Author disting mk3 startup sequence incorrect
charonme
the manual says the last two stages of the startup sequence are:
* 1 + minor firmware version number as binary on a/b/c/d (a is LSB)
* 1 + flash a twice
however my mk3 doesn't light up the "1" during the last two stages and the last stage has "b" and "d" lit up while "a" flashes twice. Does this mean there is some problem?
EDIT: I reflashed the firmware but it's still doing the same thing
oh and the first stage on my MK3 is not
a, 1, b, 2, c, 3, d, 4
it's 1, a, 2, b, 3, c, 4, d
the bootloader version seems to be 1.0
A video would make this much clearer.
charonme
https://www.youtube.com/watch?v=uLrTYHSvQkI
That looks exactly right to me.
charonme
are you sure? the manual http://www.expert-sleepers.co.uk/distingmk3usermanual.html
says:
1 + major bootloader version number as binary on a/b/c/d (a is LSB)
all off
1 + minor bootloader version number as binary on a/b/c/d (a is LSB)
a, b, c, d, 1, 2, 3, 4
all 8 at once
1 + major firmware version number as binary on a/b/c/d (a is LSB)
all off
1 + flash a twice
my sequence is different:
all off
all 8 at once
all off
minor firmware version number on a/b/c/d (1 is off)
minor firmware version number on a/b/c/d (1 is off) + flash a twice
