How was this synth arp done?
elastic
Post by elastic » Fri Oct 05, 2018 5:05 pm
Listen at 45seconds and throughout, its like the synth is playing 16th notes then changes to some other timing now and then with those little cool licks, like dotted 8ths or something?
I'm sure it was done on a monopoly too.
Sorry can't seem to get the video embed thing working.
Panason
is banned
is banned
Post by Panason » Fri Oct 05, 2018 5:18 pm
I'm sure you could do this with the right analog sequencer(s) but MIDI would probably be cheaper.
drip.feed
Roll it off at 30 Hz
Post by drip.feed » Fri Oct 05, 2018 5:35 pm
That is called Ratcheting on old analogue sequencers. Start here:
https://www.google.co.uk/search?q=seque ... e&ie=UTF-8
Dripfeed
nuromantix
Post by nuromantix » Sat Oct 06, 2018 4:05 pm
Whatever sequencer they are using is being clocked from somewhere.... every now and then they double the speed of the clocks for a moment. That's all.
You could do it with, say, a 606 or similar using the trigger out and having two different patterns, one double speed and one normal speed, and swapping between them every now and then. Or you could do it with MIDI.
Grumble
Post by Grumble » Sat Oct 06, 2018 5:02 pm
The sequencer I’m working on can do ratcheting.
It is (loosely) based on the m185 made by Rijk.
GUM
Post by GUM » Sat Oct 06, 2018 6:25 pm
moog mother-32 sequencer has 'ratcheting' built into it, in the eurorack world i believe the metropolis has it or some approximation of it
Grumble
Post by Grumble » Sat Oct 06, 2018 10:41 pm
Metropolis is also based on th m185
elastic
Post by elastic » Sun Oct 07, 2018 8:45 am
Ah ok, thats so interesting about the ratcheting thing. Thanks guys, just been reading about it.
I have a Korg SQ1 and a beat step pro for sequencing (no modular here). Can ratcheting still be done on either of those?
And a TR08 for sequencing too actually via its trigger out
Thanks :goo:
dnwrp
Post by dnwrp » Sun Oct 07, 2018 1:03 pm
and how to do it with midi?
elastic
Post by elastic » Sun Oct 07, 2018 1:05 pm
Midi would be easy, you can program different timings in a midi clip and feed it to your device.
nuromantix
Post by nuromantix » Sun Oct 07, 2018 1:59 pm
It's not ratcheting because as I understand it, ratcheting is just re-triggering the same note. The fast notes in the Drexciya track are not repeats of one note.
elastic
Post by elastic » Tue Oct 09, 2018 5:35 am
Well i achieved it on the beat step pro by simply having 2 different sequences, one playing 16th's and the other playing 32nd's, as someone above posted similar.
Only thing is with that is you have to keep changing the sequence manually, i would like to program it in a sequencer so it does it every couple of bars automatically.
Post by ??? » Sun Oct 14, 2018 10:35 pm
I use two midi tracks with the same channel. Both with different arp speed:
track 1 (chan 1) -> 16th XXXO
track 2 (chan 1) -> 32th OOOX
So you don't have to manually change anything if you have a midi arpegiator. Just put the midi clip where you want (like shown above) (x = midi part, O = nothing)
There is something funky about the arp in the song though, I can't pinpoint what it is, maybe a little bit of shuffle in the faster arp...
