Serge Preamp Detector
Author Serge Preamp Detector
srfnsmy
Anybody have the schematic (or a link to one) for the Serge Preamp detector? Looking for more wiring and signal flow info..
the bad producer
I'll send you something tomorrow!
srfnsmy
Found the infos! Thanks!
animalman
I'm interested too. I've done the Easel Envelope follower from Aaron Lanterman's schematics on stripboard. But would really want to try this one out....
Thinking this one would work better with "serge signals/voltages"
Strange that Ken/cgs didn't make a pcb.
daniel.fiction
i am interested, too!
FatRocky
hmmm.....
jersupereq
I'd love to see a DIY version of this!
FatRocky
is this the one included in the Animate panel?
why is it called preamp detector? apart from the preamp does it have an envelope follower or a comparator?
djs
Not sure if it's the same circuit as on the Animate, but if you look at the info on the Serge 215B here:
https://modularsynthesis.com/serge/box2/serge2.htm
It shows that the same pcb does both preamp and envelope follower?
user129
Also interested in a schematic or any details that are going around!
FatRocky
So with the Preamp Detector one could use the boosted signal ( for example some kick and snare from a drum machine) to be sent to a VCA. Also, with the generated Envelope one could send it to a DUSG and use the DUSG output to open the VCA (adjusting dusg rise and fall and preamp level signal ) and it would be the same effect as a VCA Compressor like an old DBX?
And with cv control of rise and fall it could be even better than a cwejman ap1
Correct me if im wrong please?
Gandalf
Preamp Detector
Two separate circuits, a preamplifier and an envelope detector
