[µTune] Transpose with scale masks
MUFF WIGGLER Forum Index -> Tubbutec
Author [µTune] Transpose with scale masks
navymaker
Hi,
I got uTune and initially planned to use it as quantizer for diatonic scales, so I have a question about choosing a key and transposing diatonic scales.
For example I have a diatonic major scale:
100.000000000 <inactive>
200.000000000
300.000000000 <inactive>
400.000000000
500.000000000
600.000000000 <inactive>
700.000000000
800.000000000 <inactive>
900.000000000
1000.000000000 <inactive>
1100.000000000
2/1
My oscillator tuned to C, and I'm getting C D E F G A B at output. When I'm trying to transpose it to 2 semitones, I'm getting D E F G A B C D instead of expected D E F# G A B C# D.
I can tune my oscillator to D and get expected shift, but is this the only way to do that(or use adder)? Or I'm missing something?
Maybe you can add to firmware some kind of root note setting for diatonic scales and also different kind of transposition(and make it also as a setting, not only from cv input) as it made in other common quantizers such as Intellijel uScale?
tubbutec
As you have noticed, 'transpose' currently works on the input note. So the scale mask remains fixed and only the active notes are used.
I agree a second kind of transpose needs to be implemented that also shifts the mask.
Will do so - and also as you suggested implement this as parameters in menu (that's on the TODO list anyway).
By the way: 'Shift' will shift the mask, but not the pitch. So it will change the scale degree. Not what you are looking for, but wanted to mention it anyway.
navymaker
Great, thank you!
