ADAT Question ?
Author ADAT Question ?
julienbayle
Hi there all, I hope you are fine !
I have a RME Fireface UC.
And a ES8 that I'd like to expand with both inputs and outputs.
As far as know, ES3 + ES6 can be used for that.
BUT, can I connect the whole things (I mean ES8 + ES3 + ES6) to my Fireface RME via ADAT for having a whole BIG amount i/o interface ??
No, though you could run the ES-8 and RME together as an aggregate - and then expand both with 2 sets of ES-3/ES-6.
julienbayle
Yes, I got that but there still is a bug in Live 10 that doesn't keep i/o setup between sessions. I logged it but they don't know when they will fix it. So aggregate is completely messing my setup every time.
I think I will already ADAT ES 6 + ES 3 with my ES8. That would be perfect as I am using now my modular rack almost only for FX / send/return etc.
Thanks for your answer
julienbayle
I mean, do you confirm I can connect
1x ES 6 + 1x ES3 to my already got ES8 ?
I just have to get ES6 + ES3, no other modules, right?
Correct. You could add an ES-7 if you want more inputs.
julienbayle
I'm sorry I don't understand.
I want a lot of inputs + a lot of outputs.
ES8 provides 4 inputs + 8 outputs.
ES3 is 8 outputs
ES6 is 8 inputs
So, through ADAT connection between ES8 + ES3 + ES6 I got:
12 inputs + 16 outputs, right ??
and I can retrieve that on my computer through USB connection on the ES8
Am I right ?
(in that case I wouldn't need a ES7)
ES-6 only provides 6 inputs.
julienbayle
Ok Andrew!
I did't get that, and that would be enough in my case.
Ordering this on modularsquare asap
