Scala help please
Author Scala help please
ketem13
I just download and install scala to my mac
I create a 24 equal template but when I tried to play some note nothings comes up. and I've got a message that says: No Midi devices available .
I follow all the instruction and download the SimpleSynth software etc etc.
I do hope to solve this problem soon.
Many Thanks!
shreeswifty
you are most likely going to need to enable the IAC buss
-Go->Utuilties-Audio and Midi Setup
check online IAC bus
give yourself one or two busses
go out from Scala into your DAW midi in on iAC buss
choose a synth to set t receive the microtonal midi
ketem13
My IAC bus is online and I also added another bus but still no midi devices in scala.... hmmm.....
what do you mean by: "go out from Scala into your DAW midi in on iAC buss
choose a synth to set t receive the microtonal midi"
10 Miles High
Bump !
Exactly the same problem here. Scala is working fine, Simple Synth is running, IAC is enabled and online.
But in Scala's sound settings I just can't get any MIDI output going. The menubox is greyed out.
thanx for any hints
10 Mh
poolbath1
Same problem here. Nothing I do ever gets a midi device to show up in the menu of midi devices.
10 Miles High
I contact—É–≤ the developer via email. He answered that this is strange and a not commonly known problem. But then I tried the thing on a machine running OSX 10.7.5 (Lion) - same result. Which I passed to him. Then he replied that now it seems to him that the problem lies within Scala/X11 and there is a fix needed but right now he es too busy to maintain this.
Looks that we're busted (
10 Mh
