µTune midi gate and 0 coast
MUFF WIGGLER Forum Index -> Tubbutec
Author µTune midi gate and 0 coast
tubbutec
ketem13 wrote:
sending midi gate from the gate output.
so I got an 0 coast which has a midi input.
I try to send midi gate from the gate out of the utune to the midi in of the 0 coast and then the gate out of the 0 coast to trigger some envelope but nothing is happening.
any helps with the above ?
Hi,
midi gate does not output any midi information. It outputs a gate signal when µTune receives a midi note on/note off massage.
If you want to connect midi out from µTune to the 0 coast, you can use the din-midi output with an adapter to 3.5mm jack
Or you use the µTune gate-out to trigger the 0 coast with its gate input
ketem13
Hi,
will it output a gate signal also when receiving signal to the cv input of utune ?
tubbutec
Hi,
In the beta version there is a function called 'auto-trigger' which does that
