Author |
Expert Sleepers with Ableton, the ultimate combo ? |
br>-S.L- |
br>Yeah I admit it, the title is a bit of a teaser, especially to get Os attention !
So like what it says on the website : IN DOUBT, ASK
But this is what I try to archive, and hopefully I'll get some answers, althou I do have some of my answers already.
Sequencing from Ableton to Modular World is easy: FH-2 plus its expanders for CV & Gates , i mean by that : for basics triggering and voices V/oct stuff for example.
Now lets say you want to keep it as simple and compact as possible, and use the power of Ableton in terms of mixing channels (EQ-compressors, effect etc...)
So I if i want my audio (the voices, and sounds coming from the modular) to go back to Ableton, A.K.A Multitracking I would need to send these into a couple of analog input from the modular, which if I understand correctly, the ES-8 and ES-6/ES-7 would be the choice , correct ? And this without the need of another external soundcard, as we also could use two outputs from the ES-8 as the main sum out of everything (maybe using an output module with big jack or XLR after)
How many ES-6/ES-7 can you actually chain ? As far as I understand
Many thanks for the info ! br> br> |
br>-S.L- |
br>or not ? br> br> |
br>mrkhckrdg |
br>I’m looking for similar information on how I can integrate the ES-8 with Ableton Live/VCV via a Focusrite Scarlett 18i20. I want to be able to send Audio and CV/Clocks/Triggers both ways between my 6U and an iMac running Ableton 10 & VCV. Is this possible?
I understand that the audio interface needs to be DC-coupled (which the 18i20 isn’t). But I also read somewhere that it is possible via ADAT/Lightpipe.
Could anyone be kind enough to explain this to me as I’m struggling to get my head around it to be honest. Yes I’m a relative newcomer!
Thanks cool br> br> |
br>os |
br>@-S.L- If I understand you correctly you're asking if you can use the ES-8 as the only sound card in a system, and record multitrack audio into Live. So yes, you can. The ES-8 has 4 inputs. Adding an ES-6 adds another 6; adding an ES-7 to that adds another 2. So total 12 maximum.
@mrkhckrdg I think you posted this on another thread? So you can connect the ES-8 to the 18i20 via ADAT. Or, you can connect the ES-8 to the computer via USB, and talk to it directly from VCV using the VCV audio interface module. br> br> |
br>-S.L- |
br> os wrote: | @-S.L- If I understand you correctly you're asking if you can use the ES-8 as the only sound card in a system, and record multitrack audio into Live. So yes, you can. The ES-8 has 4 inputs. Adding an ES-6 adds another 6; adding an ES-7 to that adds another 2. So total 12 maximum.
I wished it has 16 Ins in total, but yes that's correct br> br> |
br>geetee |
br> -S.L- wrote: | os wrote: | @-S.L- If I understand you correctly you're asking if you can use the ES-8 as the only sound card in a system, and record multitrack audio into Live. So yes, you can. The ES-8 has 4 inputs. Adding an ES-6 adds another 6; adding an ES-7 to that adds another 2. So total 12 maximum.
I wished it has 16 Ins in total, but yes that's correct  |
now you're just being greedy! br> br> |
br>Brantman99 |
br>Hey, I hope you are all well.
Would anyone be able to (n) think of a solution for this set up possibly please?
I am trying to achieve a connection between my eurorack via a disting mk4 through an MX-1 into Ableton and vcv rack with a saffire pro24. I currently have my eurorack coming into the MX-1 ok. I'm able to use the vcv rack audio module to receive the audio via the mx-1 but there is a feedback loop somewhere.
Thanks br> br> |
