PolySix key bed wiring order
Support and discussion of Tubbutec products.
Moderators: Kent, infradead, tubbutec
withakay
Post by withakay » Sat Nov 17, 2018 6:11 pm
Hi,
I am trying to get a Modypoly installed in a PolySix that had an ancient Kenton Midi board installed. When that Kenton board was installed (I guess) the wiring from the key bed ware replaced with some ribbon cable and DIP connector that mounted onto the Kenton PCB.
I need to replace this wiring and put it back to how it came from the factory, does anyone have the pin out or even just a photo would help?
I have what I think is the newer PolySix where the wires are black and white from the keybed rather than yellow, not sure of that makes any difference??
tubbutec
Post by tubbutec » Thu Nov 22, 2018 6:23 am
Hi can you post a picture?
I remember once removing a (Kenton?not sure) kit from a Polysix and they cut traces in the Arp-clock section. So in case this is not working, you know why ;)
Return to “Tubbutec”
