Teensy 3.6 Module: Humours [WIP]
Author Teensy 3.6 Module: Humours [WIP]
Sin_Phi
Looking for some feedback in case I have missed anything obvious or people have suggestions.
A bit of story to the idea. I have seen a lot of the arduino/teensy diy modules that tend to replicate the ornament and crimes concept. Most have rather limited CV control and menu based interfaces instead of something more immediately playable. I had originally conceived of something similar a few years ago and asked some questions on the Teensy forums, since then there has been some significant development of the audio libraries. So I think it is a good time to develop something around that library.
* note the circular layout is the old layout that people are referring to in their posts. Going with the rectilinear layout going forward.
My core concept is to make something for granular synthesis, but it will be easy given the hardware to do an implementation of karplus-strong or a dual delay.
I have a living concept document out on my site http://www.sinphi.com/synths/humours/humours.html some of this content will be repeated in this post.
Audio input and output (as well as the mod in and out) are handled by the CS42438, a 24bit 192kHz codec over TDM (SPI0).
The SD card links to the Teensy through the full 4bit interface with an adaptor for maximum throughput. Used for loading samples and recording a buffer for granular effects.
The 8 CVs are buffered through MCP6004 OpAmps to a ADS8332 16bit 500kS/s ADC (SPI2).
The 12 potentiometers go through a pair of 4051 CMOS multiplexes to the 12 bit (4096 steps) ADCs on the Teensy 3.6. This allows for variable responses for the attenuverters/attenuators and the main parameters. Also gives the possibility of 12 parameters independent from the 8 CVs.
There are 5 buttons directly wired to the teensy. I was feeling like there should be some dedicated to mode and not sharing with the gate function, but not sure there is the panel space for that. They are independent from the gate inputs so they can be used as alternate functions.
The 8 RGB LEDs are WS2812 (neopixels) that use a single wire non-blocking protocol.
RAM can be expanded with up to 8 SPI SOCI-8 ICs (SPI1). Some options are: SRAM 23LC1024 with 1Mbit $2, SRAM IS62WVS2568 with 2Mbit $3, and for big capacity FRAM CY15B104Q 4Mbit $25 (there is a 4Mbit SRAM for $5, not yet sure that will work as it is 2 dies). 1Mbit gives roughly 1.4s of delay, so with 32Mbit there is 22.4s of stereo buffer.
Digital +3.3V is provided by a switching supply, R-78E3.3-0.5. Analog +3.3V is provided by a linear regulator, LD2981ABM33. The -10V reference is made with a shunt voltage reference, LM4040B10. Still looking into all the other voltage references.
If you have a 24in monitor the mockup should be roughly actual size. Unfortunately the IO board has SMD on both sides with the LEDs, but it shouldn't be too difficult.
*need to update schematics
PDF IO Schematic
PDF Main Schematic
The code will for sure be open source as well as the schematics. Not fully decided if I will open source the board files yet, thinking I will after I build a few.
ayruos
Looks cool, looking forward to what comes out of this!
w00t
av500
while I love circles and circular layouts, I think these 8 jacks in the middle will be in the way all the time when trying to access the pots nearby.
Sandrine
Initially I thought this was quite interesting as I am presently doing research on emotions in music and foreign / ancient scales, but then realized it is more of a granular type FX module (correct?)
I'm curious as to the partitioning of the humours and what they represent in the FX/manipulation of live/sample audio I/O...
I'm probably missing something obvious but the design/layout is intriguing albeit possibly only a reference/UI rather than emotional representation?
Scolbio
Looking good, so are you using the granular object in the library or is it
something different?
toneburst
Intrigued! I'll be keeping an eye on this thread.
I'm especially intrigued by the fake SD card PCB, allowing access via a ribbon cable to another card slot on the front, presumably.
Did you copy this design from one available elsewhere, or come up with this from scratch?
mOBiTh
[quote="toneburst"
[/quote]
Even better than that, it looks like the fake SD mates with an 8pin header and is routed through to the front panel SD Card slot via the sandwich headers - so no ribbons cables - skills! hihi
Sin_Phi
That is certainly a starting point, but this will require going beyond that. It is useful to have the library so that I can just drop a bit of delay or reverb on top of custom code. There are plenty of other granular [/quote]algorithms floating out there that I wouldn't mind giving a go at implementing.
The little SD card pcb is intended to port the 8 pins out to the front panel. This is so that the full 4bit interface is available and it won't eat up one of the 3 SPI lanes available on the teensy 3.6.
It is not a copied design, obviously I am relying on the open source resources available in the Teensy/Arduino, datasheets, and synth community. If you were talking specifically about the SD card adapter, that is just from a datasheet on dimensions.
The layout is just something I found visually appealing. Not planning on making the module dependent on blood letting to balance your humours.
toneburst
Ooops, sorry. Yes, I was talking about the SD adapter. I didn't mean to imply that the whole design was copied in any way. Sorry if my choice of words was ambiguous.
I asked about the adapter because I'd had a similar idea a while back, while helping beta test the Euxoloti Eurorack adapter for the Axoloti. I'd never seen anyone actually do this, but that was a while ago, and I was surprised at the time that nobody else seemed to have thought of it. I'm really glad someone has done it now smile
Let's not get sidetracked, though wink
It looks like an interesting concept, and there's lots of potential for fun with granules.
I do share some concerns voiced above about the layout. Having the SD card slot in the centra makes it look like it's the most important part of the panel, which wasn't necessarily your intention, I think. I also worry that, with all sockets in the central ring populated with cables access to the SD card might be quite difficult. This may or may not be an issue in practice.
Perhaps more importantly, cables in the centre may also make tweaking the pots in the outer ring a bit tricky.
I guess it's a matter of building one, to see if either of these potential problems are in fact problematic in practice.
I'm also intrigued to find out more about what the various oddly-named controls would actually do.
Keep up the good work, anyway, and sorry again if I caused any offence.
a|x
Timmy
Looks interesting! Go for it! Nice to see a fresh design that doesn't leech (pun intended) off others. I like the conceit (used in the 7th sense as listed in https://en.wiktionary.org/wiki/conceit).
Based on experience with O&C, I would advise against releasing the PCB files under a liberal open-source license (such as the MIT license), because others will immediately sell PCBs for their own profit, but you'll be left to carry the DIY support burden. Instead, either sell PCBs to offset some of your R&D and DIY support costs/time, possibly via the existing modular DIY stores on commission (unless you like visiting the post office every day to send off packages of PCBs yourself...). Or release then under a Creative Commons Non-Commercial license, and explicitly request third-party vendors to either buy PCBs from you or separately license the design from you under a non-open-source license that permits them to sell PCBs or finished modules in return for royalties to you. Even then, many will ignore those license conditions, but some at least will do the right thing.
Schematics are trickier. I dislike designs for which schematics are not available. So you could at least license the schematics under a Creative Commons Non-Commercial license, which at least indicates clearly your wishes that the design isn't reproduced for commercial purposes without your consent. However, in most countries, circuits aren't copyrightable, so such licenses aren't enforceable in law. But they can still be used to exert moral pressure.
Definitely open-source the code, though.
TheMentat
Sweet... I’ve got a 3.6 sitting in an idle breadboard that has probably just found a more permanent home!
OIP
looks really interesting! i'd certainly be up for buying + testing a PCB should you get some stocked.
elodin
+1. Fully patched, those pots are going to be tricky.
Otherwise, the module looks exciting. Following. thumbs up
emmaker
Couple of comments:
Looks like all the components are on the inside when assembled. Going to be hard to troubleshoot that way.
There is a lot of IO there and the audio can suck a lot of processor time. Have you prototyped this and written code to see if there is enough processor to handle it all?
MatrixModulator
wow how did i missed that! eek! eek! eek!
that new teensy sure will drive new ideas and modules the modular world!
I think it will be okay, there is space at left and right of the center pots.
Sin_Phi
Big update to the images in the first post. I have decided to forgo the circular layout. Was just going to be cramped and I got some added benefits by going rectilinear. Took a while to realize I shouldn't try to jam 16 pots in there and just go for 4 main for the "humours" and then left and right "offsets" of those.
Now there is a mod in and mod out for both left and right channels that will go through the audio codec, perfect for send return or feedback path patching!
Not really set on the ABCD WXYZ labels, thinking of going with the 4 fire, water, wind, earth alchemical symbols for either one side or both. Perhaps some planet/element symbols for the gates. Would fit with the theme and with the ability to arbitrarily assign functions, just misses out on having labels actually mean something....
The board layout is mostly done. Still getting all my voltage references figured out without just resorting to expensive buffered references, though given the overall cost of the project another $20 won't make or break it. Need 3.3v for pots, 4.096v for the CV ADC, 5v for the audio codec, and 10v to offset the CV!
One thing I feel might be missing is buttons just for functions, those will have to be shared with the gate buttons by using press and hold or combos. Not ideal, but probably better for the layout in the end.
I did have a thought of using 4 switched encoders for the 4 central parameters, but not sure that will add as much function as complexity. Anyone have thoughts on that?
I am going to order up some prototyping stuff soon, there is a pedal project for the 3.6 that should serve as a decent playground for code development.
av500
I dont see why you would need 5V and 10V, you can always up the gain in the CV offset circuit to use a 5V reference instead of 10V
3.3V for the pots is not critical, assuming you use the CPU ADCs you can use the standard 3.3V as a ref for the ADCs and the pots...
or you could have CV ADC and audio codec share the 4.096V ref...
sleepgardens
Do you mind linking that? I would really like of what this module would/could do beside the generic "granular effect" label. Or could you explain what you want this module to do sonically?
Sin_Phi
@sleepgardens It is a really solid project, and actually covers a lot of the ground my module will, just with less CV and IO. Honestly this with a CV to MIDI module could probably do what I intend from this project. https://www.tindie.com/products/Blackaddr/arduino-teensy-guitar-audio- shield/
As to what I want to do sonically, I am not 100% on that. I know for what I am doing with my modular I would like something that I can use as a delay into reverb or granular into reverb with resonator so that I am not eating modules for stuff I always patch anyways. In the end I want it to do some sort of hybrid of effects that all influence each other based on 'balancing the humours'. That way it isn't directly doing something like adjusting room size, but doing something like making the sound darker or brighter.
*also as of December the Teensy 4.0 with a Cortex-M7 is in beta testing, so I will be keeping an eye on that
