current projects - hale
dksynth
Post by dksynth » Mon Nov 19, 2018 7:26 pm
I'm putting this post up as an "all in one place" to share mockups, schematics, and BOMs of things I've been working on.
PCB/Panel sets are going to be available from the usual suspects in the near future...and for built prices contact me directly via PM.
Please note that any original Serge circuits are posted for my own personal use only with notes and mods that might be useful to others. Occasionally I will have extra PCBs but I am not making these for resale.
Everything is for LW format.
So far over these past couple months I've done:
CEM3340 VCO - verified
Inspired partially by the digisound implementation but several changes became necessary:
-SINE shaper is changed to the usual differential transistor pair. Values are for +/-2.5v output. If you want a different amplitude, you will have to do some math.
-PWM control was insufficient. rectifying buffered CV processor added.
-Hordjik tuning scheme added. notes here: http://www.alfarzpp.lv/eng/sc/Tuning%20the%20AS3340.pdf
-Not sure yet about how best to do the hard sync, the datasheet implementation as used in the digisound was supposed to have some processing and overdrives the sync pin. Right now I've attached the + point through a 2k2 resistor to the sync jack and that works.
-All outputs buffered
-REF02 +inverting buffer provides clean +/-5V rails and -5v rail powers CEM3340 chip. There is a jumper option for the main tuning pots to use them OR power rails as CV source.
NOTES: This has only been tested with coolaudio 3340. I'm waiting for other brands to come in to see if values need to be changed.
Nomad roland-inspired filter - verified
-middle-years roland filter with sk30 buffers and feedback
-borrowed pole mixing and VCA ideas from mutable instruments' ripples
-component values in several areas can be changed to emulate different roland filters
-Voltage controlled resonance
SK20 dual sallen key MS20 filter - verified, new design pending
-dual version of original MS20 sallen -key KORG35 chip filter.
-link and HP/LP switches
NOTES: Verified SMD layout but extremely sensitive to interference, capacitors in filter core are microphonic. Redesigning to use KORG35 chip reproductions and isolating things to improve noise immunity.
Ornament and Crime for 4U - verified
-Ornament and Crime module for 4U
-New panels have orientation changed to be more in line with Serge standard
new panel:
RES EQ - verified
-modded to isolate upper/lower combs or stock behavior with jumper settings
-personal use, schematic posted
NOTE:Upper/lower comb buffers have been swapped to inverting and these have optionally been patched into the feedback side of the EQ knobs. this eliminated the bleed between combs and higher resonant settings.
Triple Bandpass Array - pending verification
-inspired by serge triple bandpass but using different, clean SVF core
MONSOON 4U:
https://github.com/dksynth/MONSOON-4U
raisinbag
Post by raisinbag » Mon Nov 19, 2018 9:25 pm
YES you know I'm down for it!!!! :sb:
dksynth
Post by dksynth » Tue Nov 20, 2018 6:06 pm
upside down O_C confirmed. I think this will be the "standard build" .... it is much nicer to use with how other serge is usually laid out....
J3RK
Post by J3RK » Wed Nov 21, 2018 3:50 pm
I definitely want that O_C!!!
meatcliff
Post by meatcliff » Wed Nov 21, 2018 7:50 pm
great looking work!
ashleym
Post by ashleym » Thu Nov 22, 2018 1:05 pm
I will be interested in a couple of these. I am in the UK (unfortunately drifting away from the coast of mainland Europe). Will you be shipping overseas? If so, I will message you.
TIA
Edit, any thoughts to add this to your thread in the DIY section in case people don't look at both?
dksynth
Post by dksynth » Thu Nov 22, 2018 7:34 pm
ashleym wrote:I will be interested in a couple of these. I am in the UK (unfortunately drifting away from the coast of mainland Europe). Will you be shipping overseas? If so, I will message you.
TIA
shipping overseas is fine but I'm in canada and there is a postal strike on right now. Some of the usual synthDIY shops have inquired about having a couple sets of different things, might be best to wait until that all gets sorted out since those guys will 100% have cheaper/faster shipping than I will.
I'm posting projects on the DIY section on specific modules as they are completed and ready for others to play with
ashleym
Post by ashleym » Fri Nov 23, 2018 2:33 am
Ok. Thanks for the reply. I’ll hang on and hopefully the route you suggest works out. Stirling work!
sawersky
Post by sawersky » Sat Nov 24, 2018 5:44 am
Do You know when the shops will have them in stock ?
More or less?
Unless You are happy to ship them to EU perhaps>
TTTTT
Post by TTTTT » Sun Nov 25, 2018 11:48 pm
nice project! I was going to buy the Synthrotek DIY module but I really prefer to build it myself from scratch! so, I don't know what to buy for cyber Monday.
:roll:
dksynth
Post by dksynth » Tue Nov 27, 2018 9:21 am
v1.0 Ornament and Crime are up.
I have 9 PCBs and 6 panels and 3 "b-stock" panels. b-stock panels have breaks in the border or inconsistent line thickness.
edit- b-stock panels gone
PCB is 10$, Panel is 15$, b-stock panels are free with purchase of PCB.
worldwide shipping at cost.
dksynth
Post by dksynth » Wed Dec 19, 2018 1:56 am
The Triple Bandpass exists!
it is built like this with the SVF cores on removal cards:
I built the first ones with Neil Johnson's 18dB 3 stage SVF mostly because I always wanted to try it ... I have more "vanilla" SVF cards on the way that will be the standard build.
dksynth
Post by dksynth » Wed Dec 19, 2018 12:48 pm
here is a short sound sample of the triple filter. I'm using only it as the sound source, with all three channels set to self-resonate.
This is using the 18dB SVF from Neil Johnson, which track quite well and are fully resonant.
the bad producer
Post by the bad producer » Wed Dec 19, 2018 12:58 pm
Nice one! :yay: Can't see / hear sounds though!?
dksynth
Post by dksynth » Wed Dec 19, 2018 1:13 pm
Embedding seems to be broken... swapped the link in
neil.johnson
Post by neil.johnson » Wed Dec 19, 2018 5:42 pm
Nice demo :tu:
Neil
Random ramblings :: http://www.njohnson.co.uk
SSI parts and more :: https://www.cesyg.co.uk
dksynth
Post by dksynth » Thu Feb 07, 2019 9:43 am
Moving a little slower on some of my own stuff because I'm redoing the Best of CGS panel set right now to finally build these panels I have
Part of my no-more-panel-wiring vendetta.
First up, SWAMP! Might even be able to get it into a 2" boat!
It's highly unlikely that these PCBs will be fully released as they aren't my designs but I'm happy to let go of extra PCBs .... drop me a line if you are interested but it is all SMD so fair warning!
dksynth
Post by dksynth » Thu Feb 07, 2019 12:35 pm
.....and, coming soon thanks to Mutable Instruments' open source ethos and the generous work of mr JM Jak Plugg:
4U Monsoon!
cygmu
Post by cygmu » Thu Feb 07, 2019 12:37 pm
Very nice!
Boofin Moonrocks
Post by Boofin Moonrocks » Thu Feb 07, 2019 5:50 pm
That's awesome!
dksynth
Post by dksynth » Thu Feb 14, 2019 5:54 pm
Exciting progress on the triple filter.... the main SVF I wanted to have in it was the ARP1047 resonator from the ARP2500. I thought it would take quite a bit of work with all those discrete gain cells but I’m happy to say it popped to life right away! Needs some fine tuning to keep it stable at high resonance through the range but it is very close... you can almost lock to single harmonics with the bandpass ... Should have some things finalized and sound samples this weekend.
dksynth
Post by dksynth » Sat Feb 16, 2019 11:34 pm
1047 filter card is a go!
Some sound samples:
-using 3 in series at reasonable high q. Blue trace is input signal. The input is almost completely inaudible and you can hear it locking to harmonics nicely.
-using just one at high resonance. A pair of saw waves are input tuned a 6th apart. I'm using a 8 step programmer to "play" the resonant harmonics.
And a flowchart of where exactly I put those compressors:
The idea is, these things are capable of quite a bit of gain at higher Q levels. You have control of the input volume but not between VCF 1 and 2 and VCF 2 and 3. So the compressor limits things to something they are happier with. They can be bypassed and adjusted, you have control of Ratio, Makeup Gain and Threshold.
the bad producer
Post by the bad producer » Sun Feb 17, 2019 7:43 am
Where will these - and the other projects, I'd like to get the 3340 VCO for example - be available? Will they be stocked at Modular Addict or Synthcube etc?
dksynth
Post by dksynth » Sun Feb 17, 2019 12:32 pm
the bad producer wrote:Where will these - and the other projects, I'd like to get the 3340 VCO for example - be available? Will they be stocked at Modular Addict or Synthcube etc?
I've sent my first box (OC, Nomad and 3340) to Modular Addict, Synthcube said they wanted some but haven't got back to me yet.
Shoot me an email if you like.
Boofin Moonrocks
Post by Boofin Moonrocks » Sun Feb 17, 2019 5:50 pm
Nice. Excited to buy a couple of o+c sets
