Nutella Tsunami
Author Nutella Tsunami
M4ngu
Hi, this is Nutella Tsunami, an eurorack conversion module for the Sparkfun Tsunami Super Wav Trigger,
it features:
-16 trigger ins and buttons to play ".wav" files.
-8 audio outs (modular levels)
-32 voices polyphony in mono, 18 voices in stereo mode.
-microSD card slot to store up to 4096 wav files
-Low latency (8ms tipically)
-Midi in (velocity sensitive, supports MIDI Note-On, Note-Of, Pitch Bend and Program Changes messages, as well as Controller messages for real-time control of sustain, attack and release times and volume.
-Ability to play multiple audio stems in sample-locked sync.
-Can be used as a Wav player and Midi-to-Trigger converter at the same time.
-Trigger ins (and so buttons) can be assigned to various functions (normal, next, previous, random, pause, resume, stop, volume up, volume down, trigger bank up, trigger bank down, synced set, midi bank up, midi bank down)
-Easy configurable by an optional ".ini" file stored in the microSD card, a Tsunami Configurator utility (Windows, Mac and Linux versions available), makes it easy to set options and generate this file.
-Super easy firmware update system via microSD card, no external programmer needed.
I'm selling pcb+alu panel kits & also assembled modules, if you're interested visit the Tesseract Modular's facebook:
https://www.facebook.com/Tesseract-Modular-146727136274298
or drop me a mail to:
tesseract.modular@gmail.com
Manual/build guide:
https://drive.google.com/open?id=1n9J3baKEew5DDWzT5Faxcn1-AQwBXxvrJlFo jfTVx9Y
BOM:
https://docs.google.com/spreadsheets/d/1SREqpzPe2Li5pRSL5EuF8iNjBchi9_ oua5kS9FYo8OA/edit#gid=1759943668
Mouser cart:
https://www.mouser.es/ProjectManager/ProjectDetail.aspx?AccessID=57490 66b03
More info about Tsunami (lots of info indeed):
https://robertsonics.com/tsunami-user-guide/
ersatzplanet
I love this addition to the Tsunami module. I had a Tsunami laying in a box for a couple of months just waiting to make a module out of it (I had made 2 modules from its cousin the WaveTrigger) and snagged a Nutella the second I saw it. I use mine mainly for playing loops, a "modular Ableton" and it works great. I am making a mod to it though, I'm wiring some parallel buttons to the ones on the Nutella front panel. It looks like this -
The pushbuttons for momentary playing of loops and the toggles next to them to play continuously. The black/white button pattern is laid out for the chromatic octave so I can play Mellotron (or other) keyboard samples if I want.
M4ngu if you ever do a mod of this PCB, I would suggest putting on a header, if there is space, that either connects to the buttons or the gate jacks. It would make mods like this really easy and "behind the panel" too. I could have made my panel produce gates and patched into the jacks on the Nutella, but that would have been a lot of patch cords!
Zube
Woah this looks cool, as does the arcade expansion mod. Thanks for sharing.
M4ngu
Thanks for the feedback & suggestion Rockin' Banana!
ersatzplanet
Looking at the board and I just can't see where a header would even fit!
sduck
Looks cool!
Where are you selling these? Because you can't sell them here with under 100 posts. If you have a web shop set up somewhere, you can link to that, but you aren't allowed to do business directly from here. Please update your first post with the link to your shop or indicate how you are conducting business otherwise.
M4ngu
Did it!
it's correct now?
sduck
Yes, thank you!
defalut
Does the Nutella Tsunami have some way of changing sample in the 16 slots "on the fly" somehow? Is it possible via midi program change for example?
Or how does one select a new kit or sample from the card and load the slots?
ersatzplanet
The Tsunami reads the files from the card, it doesn't load them into any internal memory. All you have to do is stick in a new card and then reset or reboot the Tsunami because it needs to read the .INI file that tells it how to play the files (looped or one shot, etc.). If you are using MIDI to control it, you can just name the files by note number and use bank select if you have more than 128 samples on the card using program change commands.
defalut
Alright, thanks a lot for the thorough explanation. we're not worthy
M4ngu
Or hohw does one select a new kit or sample from the card and load the slots?
Iof course you can change the 16 sounds on the fly. One way is with midi bank change and other is assign a button (and so a trigger) to benk + or -. In my module i have trigger 15&- 16 asignned to bank up down. That means also that i can only play sounds with the other 14 triggers
defalut
I read about program change or bank change available in the product spec, and that's Good enough for my purposes. Thanks for confirming!
Dropping two sample slots out of 16 doesn't matter much to me either, i would config like you did. Nice.
autodafe
I have just built it, seems to work (leds flash when triggered) but I have no sound at all at any output...
I am using the "20 mono kits", cannot understand how the outputs are set up...
ersatzplanet
The Tsunami has two mode, mono or Stereo, but only one of those modes can be used at a time. The internal processor has to be flashed to set that mode. This is pretty easily done via a file on the MicroSD card when booted. Then that mode is set until re-flashed.
Unless the card is set to MONO, the mono kits probably will not play. Mono is the most versatile because stereo files can be faked by two mono files, but the unit may have come to you in the Stereo mode which I believe is the default.
The files to re-flash the Tsunami can be found on the makers site -
https://robertsonics.com/tsunami-downloads/
Instructions and feature sets can be seen there too.
ashleym
Nutella is the corruption of chocolate spread. Digital stuff is also the corruption of synthesisers. Where will this all end? Hopefully soon.
M4ngu
Synth Diy Guy made a little overview of this module, which is at the same time the corruption of chocolate spread & the corruption of synthesisers
https://youtu.be/6uX0qPCCKB0
M4ngu
did you make it work?
autodafe
I was able to make it work.
I have used an old SD card (sandisk) that I used on a Nintendo DS in the past...
I rformatted it may times following Sparkfun advice, FAT32 with 32Kb blocks, as mentioned here: https://learn.sparkfun.com/tutorials/tsunami-hookup-guide/all
No way, then I tried formatting for the millionth time and used FAT32 and 4Kb blocks....BINGO!
I still have leds 1 and 9 not flashing (as discussed with you on FB messenger), but all channels and all other leds work 100% and the module works great
robertsonics
Just a heads-up for all you Nutella owners. I just posted a Tsunami firmware update on the Robertsonics Tsunami download page that removes the limit on how often input triggers are scanned. This will improve the trigger response when connected to modular gear and allow it to track faster gate tempos.
M4ngu, you already have this - I'm just making it available to everyone.
paperCUT
I just finished my Nutella build! Apart from one LED not lighting up from external gates it was a very painless process. Awesome work on putting this together so neatly M4ngu! And of course Jamie cool
I'm using the only SD card I had on hand, according to the Tsunami card guide it's on the edge of suitable but so far had no problems (model is SanDisk Ultra 16G).
omote
just finished the build. I had no idea sourcing the lower spec microSD cards would be such an effort. Couldn't source them locally, so had to go the eBay route. I'm using my Morphagene card for the moment.
Thanks for making this module possible!
Bamboombaps
robertsonics
Im having real issues with my nutella and im sure the probelm is with my tsunami- it was working fine for a while, i changed cases and then changed back and its never been the same since. it was glitching when i was putting any more than a couple of triggers in and today ive been trying to reformat and update teh firmware but its made it even worse- heres the behaviour im getting now-
https://youtu.be/2bHH0mhFNeY
it starts then glitches out and does nothign unless reset, then same again
ive tried it via midi , and with an older firmware with the same results
Dan Lavin
Bamboombaps: It might not be your issue, but you may want to check your micro SD card. Let me explain: I use mine as a rompler with Mellotron samples and such and set it aside for a few weeks. When I started playing it again, I would get missed notes, distortion and just general odd behaviour. I suspected the Tsunami initially, but eventually took the SD card out and cleaned the contacts with rubbing alcohol and everything was fine again. For you it might not be the contacts, but maybe a deterioration of the SD card? Anyway, something else to try.
MuffDiveler
Bamboombaps wrote:
robertsonics
I had a similar issue with mine. Mangu is a godsend for helping me as much as he did to debug. It turned out that the testing power supply I was using did not provide enough amps at 5v to run the Tsunami. The Tsunami needs 150mA. I determined the issue by watching the Vin on the Tsunami after reset, and the voltage started at 5v but dropped down to about 3.4v which is when it would then produce that weird sound. I switched the jumper to the lower position for 12v and the issue went away.
Mangu thank you for all your help we're not worthy we're not worthy we're not worthy
In addition to what Dan mentioned about the microSD, you could bypass the front microSD slot and just insert your microSD card directly in the Tsunami so that you can at least rule out if it is the microSD extension to the front face.
