Disting - Dual Audio Playback - Files always loop
Author Disting - Dual Audio Playback - Files always loop
ForAiur
Hi there, I named a playlist playlist.txt and put this text into it:
-loop=0
-gap=0
-fadeIn=0
-fadeOut=0
-retriggerOnSampleChange=0
it is in the folder of files I want to use for the dual audio playback.
I also have other folders on the card copied from some guy at Facebook. They have wavefolders. There are two files on the main part of the card that tell disting which wavefolder files to play and so on, but all that should not create the problem I have.
Even with no CV input or a very slow input the drum files I have on the disting always loop. I never have a silent part. So this is without use for my durm sounds confused
What am I doing wrong?
Can you attach your playlist file here? If the above is the complete file, you've omitted the 'disting playlist' header.
ForAiur
I‘m not at home at the moment, but I had the same thought and added a top line that said something like
Dual Audio Playback
Before the
Things start. Didn‘t make it work.
ForAiur
Is the disting playlist name one that is not allowed to be changed? I had gotten the impression that the first line is allowed to be named differently?
No, I don't know where you got that from.
The manual says:
An audio playlist file might look something like this:
Code:
disting playlist v1
-loop=0
-gap=0
-fadeIn=0
-fadeOut=0
TR66_BD_aOrig_b_R1.wav
-fixedPitch=0.9
TR66_Snare_aOrig_b_R1.wav
sample01.wav
-loop=1
-ramp=1
funky_lp.wav
-loop=1
-triggers=4
586447main_JFKwechoosemoonspeech.wav
-loop=1
This breaks down as:
• The header: "disting playlist v1"
• Default settings (optional)
• List of audio files
• Per-file settings after each file (optional)
ForAiur
Oh, sorry, that was it, the "something like this" in the PDF made me think that the header is just a name that you can pick. Sorry.
Just tested it, it solved the problem. Thanks Os. As soon as the Disting MK5 arrives I'll buy one to honor your support wink
