Disting mk4 won't accept firmware update
Author Disting mk4 won't accept firmware update
quilter7
I have the microSD card in the disting with v4.9 on the card. I hold down the S button and power it on. The single vertical and horizontal lines go across, briefly it shows the last algorithm, and then immediately the "installing" vertical lines move past, and then it says "Success". All while holding down the S button. I release the S button, nothing happens. I turn off and on my modular and the disting tells me it's on v4.3.
Please help me troubleshoot this. Thank you.
Have you formatted the card to FAT32?
quilter7
I think we both know the answer to that question. smile I formatted the SD card and now everything works swimmingly. THANK YOU!
donr
Sorry to say I have a similar problem. Reformatted the card to FAT32, but now the module says 'Firmware not found on card'. I'm using a SanDisk Ultra Plus sdxc card(64 GB; too big?), and MacOS 10.13. Not sure what I'm still doing wrong, so any suggestions would be most welcome. Many thanks in advance.
Can you post a screenshot of the card contents in a Finder window?
donr
First time trying this, so it's probably wrong...:
Looks OK. You might try partitioning the card into two 32GB partitions.
donr
I'll give it a try. Thanks for making such a great tool.
donr
Partitioning the card did the trick. we're not worthy
