[iOS] PolyPhase - Generative Sequencer
Author [iOS] PolyPhase - Generative Sequencer
mekohler
PolyPhase is generative sequencer for the iPad
BETA: https://testflight.apple.com/join/6FXwpG97
Image: https://imgur.com/a/byFOD0O
A Master melody is generated on the fly & copied, with phase offsets, to Slave Tracks. You can DISABLE the generation of notes & draw your own sequences, or use the randomization functions.
You can sequence external hardware, other iOS instruments, or use the included wavetable synth.
There are many adjustable parameters which will guide the generation of notes…it’s extremely versatile. You can let it run all day and play for you…or, when you hear something you like, turn the Master Track OFF to LOCK / LOOP the sequences in place.
Any suggestions / feature requests are welcome before I release it!
Phil999
from a first short test this looks good. The snapshots area is very useful, and with that lot of random options PolyPhase could become a success. Although there appeared quite a lot of sequencers lately.
Thank you, well done.
mekohler
Thanks, it was received well on the Elektronauts forum a few weeks ago Rockin' Banana!
The bottom randomization functions and pattern / euclid algorithms are what really lets you come up with ideas quickly.
poppinger
Oh wait, are you the Collider guy? That thing is amazing, I'll have to check this out.
mekohler
Yep, I made Collider as well :]
mcnys
will there be a iphone version?
mekohler
I think the iPhone screen is too small to accommodate the UI. Once I release the first version I will have to experiment and see what I can change for a smaller screen real estate, and if that works at all.
mekohler
New beta is out, delete the old app first.
Snetch
I love the sound the delay makes when changing the time param
