Control of CV amount with CL instruments
home of post-70s electronics
Moderators: Kent, bartlebooth
rmro
Post by rmro » Wed Nov 28, 2018 5:24 am
For example:
PB Gong Orange Out into Coco Loop VCA (Blue Verso/Inverso)
The effect is that when the Gong triggers the Coco Loop volume increases/decreases.
My question: Is there a way to have control over the level of volume increase/decrease?
I've read about Banana cables with potentiometers/resistors but never seen one or how to diy one to test. (btw I'm no expert here) Is this a possible option.
Interested to hear thoughts on this.
corpusjonsey
Post by corpusjonsey » Thu Nov 29, 2018 9:23 am
Run the signal you want to control through a VCA?
jimmie
Post by jimmie » Thu Nov 29, 2018 2:05 pm
There was a similar thread before and I saved it for my personal memo locally, so here am quoting it (am too lazy to search the exact thread :deadbanana: )
For reducing (attenuating) voltages for Ciat-Lonbarde gear like Tetrazzi, Sidrazzi, Plumbutter, Cocoquantus, you need in-line resistors, NOT 'potentiometers' with one leg grounded. Solder together one of the end lugs with the middle lug, so it becomes a two-terminal device. A 1M audio taper pot should work well. Patch that between points. Ciat-Lonbarde outputs are like 10K and inputs as high as 1M, which makes stacking work fine without drawing too much current. Yet you can still patch to your modular and it will work!
What value pot would recommend for doing this?
A 1 Meg audio taper pot should work well. At 1 Megohm resistance, a signal will still have effect. This is why touching nodes with your fingers works. And you can dial it down to zero, where it acts like a patch cord."
If my memory serves, this was by wiggler Pugix who is generously sharing us a lot of useful and valuable information, and I hope he does not mind quoting him without asking prior (I will edit the post on a request). So, thank him! Thank you Pugix :sb:
jimmie
Post by jimmie » Fri Nov 30, 2018 10:55 pm
I'm thinking about getting one of these (asking him if he could fit banana jack and make it in-line)
http://beatnic.jp/products/fader/
rmro
Post by rmro » Sat Dec 01, 2018 3:39 am
Hi,
Thanks for the info, the faders could be a really interesting prospect. Food for thought. I will dig up the thread and have a read.
rmro
Post by rmro » Tue Feb 05, 2019 10:33 am
I made it to here: https://uk.rs-online.com/web/c/passive- ... tiometers/
Could someone please advise what I could use to do this :hail:
corpusjonsey
Post by corpusjonsey » Tue Feb 05, 2019 1:20 pm
Solder one of the outer lugs to the middle so you have two terminals: the middle/one outer and the other outer. Turning the pot will yield varying resistance between the two terminals. Solder one length of cable (banana plug on one end) to one terminal and another length of cable (again banana on one end) to the other terminal. Basically, cut a banana cable in half and solder the bare wire ends to the two terminals of the pot.
rmro
Post by rmro » Tue Feb 05, 2019 4:12 pm
Awesome, got it. Thanks.
Would this be a suitable part https://uk.rs-online.com/mobile/p/poten ... s/1355049/
corpusjonsey
Post by corpusjonsey » Tue Feb 05, 2019 6:22 pm
Richard recommends 1meg, but it's up to you to experiment. Maybe get a few values to see what you like best and report back with your findings!
rmro
Post by rmro » Wed Feb 06, 2019 4:11 am
Will do!
Return to “Ciat-Lonbarde”
