Buchla 100 cabinet MW project
boops
Post by boops » Thu Nov 29, 2018 6:59 am
As ,i want to go to the buchla 100 clones route
and as i have 5 years experience in building cases
i plan to build /offer for my self and for interested wigglers as a diy kit or built
a buchla 100 case
Can we discuss about this here ?
the goal : a 500/700 eu budget ,15 u cabinet ,with the community wishes/choices
-Psu ,
a repliqua of the original ? can be cheap
a modern as i already use in the 200 clone case with only the 100 series voltages 15v 24v ? cheaper
or with all the voltages +24v ,to have the option of use 200e/200 serie and exotic with the 100 series in the same case?
boats
5u aluminium natural /painted ,which color?
cheeks
as the originals
foldable
solid polywood/or rare exotic massif wood as walnut (i dont like this option)
painted wood
aluminium new design natural or painted to match the boats
others :
bnc lamps?
case/bag for travel
Wait your ideas ...
FS :custom buchla 203 style càbinet ,skiff new design,boat ,hardware for diy cabinet ,easel case ,new 1u to 10u to 56u and more. / New 208 buchla card 12 /
HQ small case buchla psu PCB
https://www.muffwiggler.com/forum/viewt ... 93#3118393
https://www.muffwiggler.com/forum/viewt ... highlight=
Peake
Post by Peake » Thu Nov 29, 2018 1:35 pm
+24V is very important especially for the 190 dual reverb which is a huge part of the 100 Series sound.
The two small audio transformers are usually mounted on the top inside of a wooden cabinet away from the module with a terminal strip for wiring. +24V is run to them at that point. The two reverb tanks are usually mounted to the inside left and right sides of the case.
If you're doing boats like this please prepare them to allow connection to the external transformers/power and reverb tank audio.
ST.P
Post by ST.P » Thu Nov 29, 2018 6:20 pm
i would prefer a wood case without boats as close as possible to the original:
http://www.vintagesynth.com/misc/buchla100.php
these are 25U - one can split into a vertical and horizontal case(as an extention)
it depends on how many modules will be available...
but zthee has done a good compromise with wood cheeks and boats also...
a modern psu with all the 100 series voltages - no need for 200e modules in the same case
rampy
Post by rampy » Thu Nov 29, 2018 8:39 pm
ST.P wrote:i would prefer a wood case without boats as close as possible to the original:
Agree! Boops does beautiful work, but I think the CBS era 100 cabs are among the best looking ever.
tobb
Post by tobb » Fri Nov 30, 2018 3:52 am
That would be awesome if available!
boops
Post by boops » Fri Nov 30, 2018 4:28 am
thanks for your interests
first wishes
external psu (to avoid noise )
-with modern psu ,no noise with 200 serie,is the 100 design modules are noisy ?
no 200e but 200 ?need extra 5/-15/12v
-parts to fit the reverb tank x2
-original look ,why not
extension is great 10 +15
Dont forget the low budget goal
25 x 100 modules ?,is it possible ?
can you imagine a complete cabinet ala modular grid
original look with 15U ?
i m not sure its massive walnut ,but a thin rare wood layer on polywood or MFD
PLACAGE in french ,cheaper,and more solid
i ve done a 203 custom order,with this technique pics below
a friend build this acajou case with my boats
boats are great to install the modules easily,alumium refresh the dcdc converters too. its light and solid
we look for the internal pics of the original 25U cabinet !
oh its not my shoes on the pic below :nana:
ST.P
Post by ST.P » Fri Nov 30, 2018 8:03 am
boops wrote: 25 x 100 modules ?,is it possible ?
if you have a look at lasesentaysiete´s 100 project and the list of modules,
that are announced - 15U won´t be enough.
additionally 100´s projects can follow
possibly from Buchla themself ... :eek:
wigglers who want to build a smaller system can maybe buy just the upper case or use the existing 200´s boats?!
tobb
Post by tobb » Fri Nov 30, 2018 12:17 pm
boops wrote: -original look ,why not
I am interested in original look,if hardwood.
Cheap is for sure not possible,that is normal.
Peake
Post by Peake » Fri Nov 30, 2018 3:28 pm
Gentle reminder fluxmonkey and I've been building to order some of the 100 Series modules for a few years already and have pages of home-etch build guides as well ( ebolatone.blogspot.com ) ;)
PSU must have +/-15V and +24V. At minimum biipolar 15V then add a +24V wallwart. I believe the 180 uses +24V. Some of the 410 Module Cluster derivatives such as the envelope do as well.
boops
Post by boops » Fri Nov 30, 2018 3:52 pm
And you can have 2 or 3 same module like the 158..
ST.P
Post by ST.P » Fri Nov 30, 2018 4:04 pm
Peake wrote:Gentle reminder fluxmonkey and I've been building to order some of the 100 Series modules for a few years already and have pages of home-etch build guides as well ( ebolatone.blogspot.com ) ;)
definitely :tu:
aread
Post by aread » Sat Dec 01, 2018 3:13 pm
This is my 100 clone system from a while back, its grown to 2 cases since then.
this is populated mostly with Mikes wonderful builds
separate 24v power
note the reverb tank mounting and transformers for the 190
The essential modules for the 100 'sound' is the 190/175 combination.
aread
Post by aread » Sat Dec 01, 2018 3:20 pm
Prototype model for the 101 case i am planning to build after xmas
boops
Post by boops » Sat Dec 01, 2018 3:39 pm
thanks for the pics...
duff
Post by duff » Mon Dec 10, 2018 1:24 am
aread wrote:Prototype model for the 101 case i am planning to build after xmas
That looks great. Have you got any dimensions you could share?
shoegazer86
Post by shoegazer86 » Sat Dec 15, 2018 2:17 pm
Also, our project will be offering a 24V booster from the 200 series 214 power module - so you dont need a separate 24V - just a 15V supply.
minime123
buy/sell/trade
Post by minime123 » Sat Dec 15, 2018 4:50 pm
definitely interested in clones of the CBS buchla cabinets. theyre really nice.
mini
VINTAGE SYNTH DEALER
- Buy / Sell / Trade / Repair
- We Buy Broken Gear & Parts Too...
- Huge Selection, Dependable Service
- https://tonetweakers.com
guitarfool
Post by guitarfool » Sat Dec 15, 2018 5:13 pm
I would go for one (or two) as well. Or just the front/top/end pieces and use 5 x 5U boats 8-)
jersupereq
Post by jersupereq » Mon Aug 19, 2019 9:55 pm
Seems like a dead thread, did this project ever come to fruition? Would love a Buchla 100 wooden case. :hail:
minime123
buy/sell/trade
Post by minime123 » Tue Aug 20, 2019 8:36 am
we recently met a local carpenter who seems excited to work with us. we may eventually have him build clones of the CBS buchla curved cabinets. one thing anyone attempting to clone these should consider is the fact that the originals are in 2 pieces, which is really important as a single cabinet in the same shape will be pretty heavy and difficult to move without help.
mini
