Knas Ekdahl Quad Massager 12VAC Power Supply
Author Knas Ekdahl Quad Massager 12VAC Power Supply
odditymedium
Hello, I recently got a Quad Massager form Perfect Circuit
http://www.knasmusic.com/products/quadmassager/quadmassager.php
I played a gig with it in the States and all was well.
When I got to Europe, I could'nt find a converter anywhere... not to mention I couldn't find anyone making new/old power supplies that output 12VAC / 3A anywhere...
Can anyone help me? I got a quad gig coming up soon...
Morphology
How about a 220/240v to 120v Step-down transformer, to step down the mains side of your existing supply:
Loads of cheap and cheerful ones:
https://www.amazon.co.uk/Step-down-voltage-converter-240V/dp/B001E5OSF 8
Or if you need more power
https://www.amazon.co.uk/240v-110v-Step-Down-Transformer/dp/B000NIYH94
odditymedium
turns out i messed up and the original isnt with me anymore, so i need a new one...
Morphology
well, looking on the Knas Music web site, the power supply for the Quad Massager is actually: 12VAC, 500mA with a 2.1mm plug:
http://www.knasmusic.com/products/quadmassager/faq.php
So something that's compatible is cheap and easy to find in Europe:
https://www.ebay.co.uk/itm/12V-Universal-Power-Supply-AC-AC-500mA-UK-M ains-Transformer-PSU-Adapter-Charger/331209226785?_trkparms=aid%3D5550 17%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D55149%26meid%3D167345bedd20446 c9271530d2574840e%26pid%3D101006%26rk%3D1%26rkt%3D1%26%26itm%3D3312092 26785&_trksid=p2045573.c101006.m3226
Not sure where you got the 3A rating from?
degeneratedsines
Beware that outlets are different depending on the country you go to.
The one suggested by Morphology is for UK only.
odditymedium
any links to a EU style outlet? ideally, available in poland?
BugBrand
AC/AC supplies are increasingly hard to locate - I think Farnell only has one euro-plug one now: https://uk.farnell.com/ideal-power/77de-06-12m/power-supply-ac-ac-10w- 12v-0-5a/dp/2368015?st=12VAC
(try RS too - or maybe TME)
odditymedium
if i get something like this:
https://www.olx.pl/oferta/transformator-bezpieczenstwa-ochronny-220-11 0-12v-100w-CID628-IDwRFqW.html
will it blow my massager up?
it says "up to 9A"... but i need only .5A
bad idea?
