5U Wogglebug
tardishead
5U Wogglebug
Post by tardishead » Mon Dec 03, 2018 3:15 pm
Wogglebug is something I never managed to get hold of
Is there anybody doing PCBs or a 5U version?
Or coming to think of it is it possible to recreate the functions with discrete modules?
pugix
Post by pugix » Mon Dec 03, 2018 3:39 pm
Richard
https://www.pugix.com
ualslosar
Post by ualslosar » Mon Dec 03, 2018 3:47 pm
I bought a Wobblebug in MOTM format from ebay a while back.
tardishead
Post by tardishead » Mon Dec 03, 2018 4:27 pm
There's my DIY Wogglebug.
Do you have the PCB traces fro that Richard?
eskimo99
Post by eskimo99 » Mon Dec 03, 2018 6:55 pm
2nd on the one from synthcube. Great module.
tardishead
Post by tardishead » Tue Dec 04, 2018 3:33 am
Thanks guys
And am I right in saying the wogglebug is essentially inspired by Buchla Source of uncertainty? I see that SOU is also available to DIY in different guises. Can anyone give me a brief comparison of the 2? Which is better?
sbuge
Post by sbuge » Tue Dec 04, 2018 3:04 pm
tardishead this is old thread, but I think this might help:
viewtopic.php?t=42954&sid=cbe809aefda3b ... 2bae0cda40
fac
wig MUffler
Post by fac » Tue Dec 04, 2018 9:18 pm
tardishead wrote:Thanks guys
I'd say that the SOU sort of combines a NoiseRing and the WoggleBug. The WB is more like a chaotic oscillator, whereas the NR is a random sequence generator. I have both the NR and WB in eurorack format and I also wish I had bought a Sputnik SOU when Roman offered them in MU format.
You can, to some extent, emulate a Wogglebug but you will need lots of modules. The "upper section" (referring to the old Makenoise WB) is basically a S&H circuit which takes noise or an external signal as its input (with variable gain); the output of the S&H gives the "stepped CV output" and is also run through a slew limiter to obtain the "smooth CV output". The smoothed CV is then used to control the frequency of a squarewave VCO resulting in the first "VCO out". That's just the upper section.
Then there's the lower section, whose inner workings are even less clear to me. I think it all starts with a burst generator (it generates random triggers kind of in sync with the main clock). I think the burst output is used to trigger another S&H / slew limiter block which samples from the smoothed CV output to give the "woggle CV output". This output is used to control the frequency of a second square VCO. And finally, the outputs of both VCOs are pseudo ring modulated by running them through a XOR gate to obtain the "ring mod output".
So, you get 3 CV outputs and 3 VCO outputs, all of them somehow correlated but not the same.
I tried to emulate the whole thing in PureData once and it wasn't so bad. Results were similar but not as lively. The tricky part is the burst generator, which I don't have a clue how it really works.
sduck
experimental use of gravity
Post by sduck » Tue Dec 04, 2018 10:04 pm
I've got both a SOU and a pair of wogglebugs, and to my ears they're quite different things. Both are quite useful, and neither could replace the other as far as I'm concerned.
Here's my dual wogglebug, with a bunch of extra doodads -
ImageDual Wogglebug front by Stephen Drake, on Flickr
I actually built a bunch of these - don't really know where the other ones ended up, they've all been sold by the original buyers. Each one was slightly different.
Just me
Has enough VCA's
Post by Just me » Wed Dec 05, 2018 8:37 pm
Analog Craftsman converted a WB to MU and I have ended up with it.
If I have water in my ear, is it safe for me to listen to electronic music?
diophantine
Post by diophantine » Wed Dec 05, 2018 9:12 pm
Ben at Re:Synthesis used to sell panels & brackets for the Wogglebug in MU, perhaps he still does.
Mine is next to one of my MU SOUs. I don't find there to be a large overlap between them, despite the fact that the Wogglebug was partially inspired by the 266.
tardishead
Post by tardishead » Thu Dec 06, 2018 7:09 am
thanks everyone
So I guess the consensus seems to be I need all 3 - WB, SOU and NR
pugix
Post by pugix » Thu Dec 06, 2018 9:41 am
If you look at the photos, it's built on a SynthTech prototyping board. All hand wired. All the schematics are there, though, if you want to copy them.
Unlike some wogglebug circuits I've seen, mine has two separate sample & holds, one for the Smooth and one for the Stepped.
Richard
Return to “5U Format Modules”
