SSI2144 Eagle Component
Author SSI2144 Eagle Component
cackland
Hiya,
Does anyone have the eagle cad component for the SSI2144? Can't seem to find any online... :(
Thanks in advance.
cackland
Anyone?
flts
It's a SSOP16 package, so making the component yourself should be very easy - just use an existing SSOP16 footprint / template, and name the pins according to the SSI2144 datasheet.
latigid on
Also, there's no need to even do a fancy Symbol. Just use a rectangle with the pins laid out and named as they are on the chip. When you're more confident/competent, then you could consider things like ADD/SWAP functions and so on.
MickMad
make your own, isn't this the DIY section anyway? smile
