RYO Altered States - build thread
Author RYO Altered States - build thread
J_Behan
I've built a couple of these and noticed that there is a higher noise-floor from the state outputs (on both channels) when the state pot is turned to the low-pass side (CCW).
When the pot is turned to the high-pass side, the noise is reduced. Even when the filter is fully closed (freq pot at min), you can still hear the noise.
All the other outputs are fine.
Can anyone confirm that this is normal behaviour and if there's a fix?
codenuts
Hi J_Behan,
I can confirm the noise in state mode in the left position. That bothers me a bit too. If there was a solution, it would be great.
However, I'm just glad now, because I still had a much bigger problem with my module, which I could just solve. (see video https://youtu.be/8qXj0_d4F60 in thread https://www.muffwiggler.com/forum/viewtopic.php?p=2986799#2986799)
codenuts
Is there any new information about the problem?
