Yusynth Minimoog filter don't respond to freq pot
Author Yusynth Minimoog filter don't respond to freq pot
gabrielcichero
i've build this nice circuit. It delivers filtered audio at the output, but not respond to freq pot movement.
I debuged: component and values, tested traces and conections. Changed the BC557 (i have the B version). Maybe i have to do it again, and again. hmmm.....
Any idea in how to troubleshoot to make it work ? voltage readings ?
Chrutil
Don't know much about the circuit or know how to debug it, but I have a working one if there is anything you want me to measure.
Good luck!
gabrielcichero
Good luck!
Good! I need to know the voltages at the pins of both ca3086. Put the freq an enphasis at the middle, take them off and measure each point in the socket.
I dont want to burn ca3086 ☺
Chrutil
gabrielcichero wrote:
Good luck!
Sure, with all the controls in the middle, and the two CA3046 ICs removed:
Here are the measurements for U1: pin 1 - 14
1: 4.4v
2: 2.9v
3: 0v
4: 2.9v
5: 4.4v
6: 10.8v
7: 8.3v
8: 15v
9: 10.8v
10: 8.3v
11: 15v
12: 0.6v
13: 0v
14: 0v
Here are the measurements for U2: pin 1 - 14
1: 15v
2: -14.7v
3: -15v
4: -14.7v
5: 15v
6: 0v
7: -14.7v
8: 15v
9: 0v
10: -14.7v
11: 15v
12: -15v
13: -15v
14: -15v
Note that I am using CA3046 (not 3086) Also, for whatever reason (I can't remember) I have a BC557B for the single BC557, but BC557C for the six transistors in the ladder.
Hope this helps.
Good luck!!
C
gabrielcichero
Good luck!
1: 4.4v
2: 2.9v
3: 0v
4: 2.9v
5: 4.4v
6: 10.8v
7: 8.3v
8: 15v
9: 10.8v
10: 8.3v
11: 15v
12: 0.6v
13: 0v
14: 0v
1: 15v
2: -14.7v
3: -15v
4: -14.7v
5: 15v
6: 0v
7: -14.7v
8: 15v
9: 0v
10: -14.7v
11: 15v
12: -15v
13: -15v
14: -15v
Hope this helps.
Good luck!!
C
Very helpfull!! Y have the same voltages except in pin12 that i have negative voltage in all the range of the freq pot. I dont know why...
Could you read the voltages at the Collector and Base of the BC557B?
thanks a lot for your help , im very close to make this work
