Easel Card ideas
mestlick
Easel Card ideas
Post by mestlick » Mon Dec 10, 2018 3:50 pm
I use my Easel with a 200 clone system, and wanted to have more flexibility triggering the Easel. I made a card that routes the two "to card" inputs to trigger the pulser and sequencer. Then I can use the keyboard pulse input to trigger the envelope. I used a 120k resistor to bridge the inputs to the triggers, and it works great.
I also glued some banana jacks to another card, for further experimentation. Gorilla glue worked great, and I used some shorting bars to space the jacks out and hold them while the glue cured.
Can I use a 120k resistor to go from an input to the envelope attack, sustain, or decay? Has anyone tried that? Is that what the breakout boards are doing?
How about a jack to a sequencer voltage level? Would that create a per-step external input similar to the MARF?
Is there any worry putting external voltages on these points on the card?
mestlick
Post by mestlick » Mon Dec 10, 2018 3:55 pm
Here's a video with the first card in action.
The card with the jacks is sitting there waiting for some resistors to be soldered on 8-)
angora
Re: Easel Card ideas
Post by angora » Mon Dec 10, 2018 4:30 pm
mestlick wrote:Can I use a 120k resistor to go from an input to the envelope attack, sustain, or decay? Has anyone tried that? Is that what the breakout boards are doing?
I can't remember which resistor I used on my card with that routing. It is either an 820k or 1.2m since I wanted slight variations in decay.
mestlick wrote: How about a jack to a sequencer voltage level? Would that create a per-step external input similar to the MARF?
I haven't routed the jack in to a sequencer step, but random routed to one of the steps is fun. I have a card setup wher the 5th step is random. It is a fun card since I also have random routed to the number of sequencer steps. So you get between 2 and 5 steps with the 5th step having a random voltage. It creates a nice amount of variation. It's a really cool routing IMO.
mestlick
Post by mestlick » Mon Dec 10, 2018 6:22 pm
Whoa, random to number of steps and step 5 does sound cool.
You have inspired me to start soldering up my card with the 4 jacks. I can have 6 inputs, including the two "to card" inputs on the Easel.
I also hadn't though about using larger resistors to get smaller variations.
Drillionaire
Post by Drillionaire » Mon Dec 10, 2018 6:28 pm
Here are the two cards that I've made that I find most useful. The preset manager card makes the Easel K much less frustrating to use.
As far as attaching the bananas to the PCB, I lightly sanded the PCB with some fine grit sandpaper, and then used some two part quick curing epoxy, haven't had any issues with rigidity at all.
hylaster
Post by hylaster » Sun Aug 25, 2019 8:20 pm
Drillionaire wrote:Here are the two cards that I've made that I find most useful. The preset manager card makes the Easel K much less frustrating to use.
Drillionaire What value resistors are you using betw the input jacks and the EQ parameters? 120k?
