CV, ES-8, and AUM (iOS)
Reaktor, MAX/MSP, VST/AU, etc. A place for all things soft....
JES
Post by JES » Sun Dec 16, 2018 6:02 pm
Greetings. I've got some CV going into my ES-8's input. The ES-8 seems to be working, as the input is lighting up in time with the CV's oscillations.
But I'm trying to figure out how to get AUM to convert that CV input to MIDI (or even OSC) data that I can then send to applications.
My plan is to use the iPad as multichannel granular oscillator and run it through my modular for signal processing fun.
TIA.
EDIT: I realize I might need a 3rd party app to convert CV to MIDI or OSC. That's fine, I just need it to work with AUv3 (so I can route its output to synths in AUM).
ForAiur
Post by ForAiur » Mon Mar 18, 2019 2:40 pm
Have you found a solution for your problem? Having the same questions.
JES
Post by JES » Mon Mar 18, 2019 3:56 pm
Nope. Maybe the next version of Audulus, but as of now, nothing.
ForAiur
Post by ForAiur » Wed Mar 20, 2019 8:59 am
JES wrote:Nope. Maybe the next version of Audulus, but as of now, nothing.
Is that a hope of yours or was it said somewhere that Audulus would get such an update maybe?
JES
Post by JES » Wed Mar 20, 2019 9:09 am
I had a brief exchange with the designer who said MIDI out and AUv3 would be part of version 4, but I wouldn’t wait for it to start making music. It sounds like v4 won’t appear before late 2019 or 2020. Also, software development plans often change.
ForAiur
Post by ForAiur » Wed Mar 20, 2019 10:03 am
You mean midi in CV out? Thanks for sharing.
jorg
Post by jorg » Wed Mar 20, 2019 3:42 pm
I've been waiting for MIDI out from Audulus for years. That would make it so incredibly awesome!
eclectics
Post by eclectics » Thu Mar 21, 2019 10:59 pm
I think CV to midi is generally handled by a module, not an app. Although the ES-8 as an interface can pass CV, the receiver would need to know how to handle it, and this seems to be pretty much desktop apps so far.
But there are apps for audio to midi conversion -- apparently Thumbjam even has this built in http://ipadloops.com/tag/audio-to-midi/ so you might just be able to send audio to the ipad and turn it into midi.
jorg
Post by jorg » Fri Mar 22, 2019 3:03 pm
There are numerous apps that output MIDI and there's no reason Audulus can't be one of them. The vast processing options inside Audulus could easily produce a data stream ready for MIDI output. And if there's a DC-capable digitizer at the input, there you go!
ForAiur
Post by ForAiur » Sat Mar 23, 2019 6:18 am
eclectics wrote:I think CV to midi is generally handled by a module, not an app. Although the ES-8 as an interface can pass CV, the receiver would need to know how to handle it, and this seems to be pretty much desktop apps so far.
Since I need Midi to CV it has to be handled by an app, not a device. There are 2 very complex synth apps that can do it, but no simple conversion AuV3.
AlanC
Post by AlanC » Sun Mar 24, 2019 8:37 am
Craig_Clifford
Post by Craig_Clifford » Fri May 10, 2019 5:30 am
Thought that the ES-8 acted like am audio interface for a computer. Since the output jacks are DC coupled, you could use ES SilentWay to generate CV at these DC coupled jacks. At the very least you could also send a "click" for a clock to sync a DAW with he modular. I don't think it works the other way around.
Return to “Music Software”
