FH-2: Pitch bend and aftertouch on Roli Seaboard block
Author FH-2: Pitch bend and aftertouch on Roli Seaboard block
jschussler
I have the Roli and the FH-2 talking fine (via a CME bluetooth dongle), and I get pitch and gate. But I don't get pitch bend, nor do I get aftertouch, on the FH-2. So playing a note at the top of the Roli then sliding down an interval to another note doesn't work...it only changes pitch when I lift off the key and strike a new key. Aftertouch gives nothing at all.
Screenshot attached of my config in the web tool. I have a range selected for pitch bend, and aftertouch is also selected.
Any idea what's up?
manglepup
Did you ever find a solution?
Possibly something is up with MPE and pitch bend on the FH-2. I need to check, but am still in post-moving-house disarray. I will though.
aberrant_devices
Any idea what's up?
You need to set "Last Channel" to 16.
I don't have a Seaboard Block but I just tested with a Lightpad Block and a Joué and MPE pitch bend and pressure appear to work fine on the FH-2.
