Propellerheads Complex-1 for Reason?
Author Propellerheads Complex-1 for Reason?
Wiresandones
Looks interesting. The main drawback is that it appears you need the latest full Reason which I don't have.
Anyone checked out the demo or purchased yet?
http://cdm.link/2018/12/complex-1-reason-modular/
"Complex-1 is a modular synthesizer from Propellerhead Software, bringing the quirks, freedom and sonic depth of modular synthesis to to your Reason Rack. Boasting a 4x oversampled synthesis engine, a freely routable signal and modulation path and a sound like nothing else, Complex-1 is a synth lover’s dream machine."
https://www.propellerheads.com/en/reason/rack-extensions/complex-1
Luap
I have it.. In my humble opinion this is one of the best things the Propellerheads have done in years. Really.
It sounds great, and isn't difficult to use at all. The front patching feels a bit weird for Reason to begin with, but you soon get used to it.
Some excellent sound designers worked on patches for it too.
And yes, I believe it needs Reason 10.1 or later.
(Side note, the new Quad Note Generator player is also very good!)
Wiresandones
So torn as it’s a lot of money to upgrade when it’s solely just for this.
Yet ...Seems like a perfect way to focus as other modular solutions get out of control for me so quickly... when you have too many options it’s hard to get things done.
noeticsound
I’m having a blast with Complex-1.
Wiresandones, I agree with your critique of the overwhelming choice of other modular systems. I suspect you meant software modulars particularly, but Eurorack’s been giving me option saturation lately, too.
Complex-1 strikes me as a well-specified collection of modules that, together, are deep, flexible, and powerful but are nonetheless not without limitations - limitations that ultimately inspire creativity.
If you already own Reason 10 and are into modular synthesis, it’s a no-brainer.
ben_hex
Just made a big tutorial for Complex-1 having first worked on some presets for the software. Hope it's useful smile
https://youtu.be/XRbUrNEjbj4
"Try Reason and Complex-1 free for 30 days:
http://bit.ly/DivKid-Complex-1
www.patreon.com/divkid
00:00 introduction
00:28 Complex-1 overview
SOUND GENERATORS
Complex Osc
01:00 Buchla 259 heritage and features
01:40 Waveforms and waveshaping
02:28 Mod bus - FM / frequency modulation and modulating FM depth
03:03 Mod bus - AM / amplitude modulation and modulating the AM depth
03:53 Mix output - modulating the crossfade between the oscillators
04:18 Building complex tones with internal modulation, cross modulation and feedback
05:05 Audio rate modulating waveshaping
Osc 3
05:16 Osc 3 overview
05:40 Osc 3 as even more audio rate modulation for the Complex Osc
06:29 Range control, turning the Osc 3 into a sub audio rate LFO
Noise
06:46 Noise overview and sound demos
06:58 Red noise
07:15 Noise as a FM / modulation source (tool for learning and new sounds)
07:59 Blue noise
08:13 Jitter, instability and “life” with noise modulating oscillator pitch … or “how to make an angry bee in a can live in your waveforms
08:55 Resonant noise
09:52 Band noise
10:01 Static noise
10:10 Binary noise
10:16 How to make dial up internet modem sounds … wooohooo!!!
11:00 Modulating / sequenced noise as an audio rate modulator for oscillator wave shape
11:22 Buffer noise
SOUND SHAPERS
Shaper
11:58 Shaper set up and functions
12:26 Saturate - overdrive and PWM like FX
12:52 Wavefolders - what are they? How do they work?
13:08 Fold 1 - wave folding and PWM-like symmetry FX
13:36 Fold 2 - more VCO sync like tones with the second fold mode
13:59 Bipulse - wave-wrapper-esq. tones with a curved, folded, rectified like wave
14:25 Pickup - pick up style overtones, great when modulated with an envelope
14:40 Processing external audio through the Complex-1, hit tab and patch the rack!
15:01 Glitch - adding kinks and inaccuracies in the waves for rich and buzzy overtones
Filter
15:43 Low pass filter
16:14 Audio rate filter cut off modulation for formant / vocal / vowel / glottal tones.
17:03 LFO filter wobbles
17:17 Filter drive - filter burn and fattening
17:26 A word on filter key tracking
17:44 High pass filter
17:57 LPGs / Low Pass gates - what are they? How do they work? What’s unique about them?
19:29 Percussive LPG set up
20:32 Alternate ways to use the LPG
Comb Delay
20:52 Comb Delay set up and explanation
21:13 Karplus Strong Synthesis - what is it? Set up and sounds.
22:30 Using modulation for chorus / flanger like sounds
MODULATORS
LFO
22:53 LFO functions - rate, shapes, sync/reset, positive and inverted negative outs.
23:26 Clock sync-like effects with the reset input
24:17 A basic look at uses of normal and inverted LFO outputs used in a patch
24:58 Decay shape - falling envelope like shape
25:23 Step up 3 and 4, Step up and down
25:44 Smooth random - the secret sauce! smile … using it to create drift, “life” and an organic moving base texture to patch around.
ADSR
26:44 ADSR, set up, patch, inverted outputs
UTILTIES aka the real magic of a synth!
Mixer
27:56 Mixing oscillators pre-filtering
28:31 Mixing CV modulation for more complex interesting and animated modulation
29:14 Mixing unit “offset” voltages
30:18 Modulating modulators
30:40 Chaining mixer channels for up to 4 channel mixing
Lag Processor
30:58 Lag processor - slew, lag, glide, portamento - what is it?
32:08 Using the lag processor as a second low pass filter
32:41 Creating more fluctuating smooth random voltages
Scale & Amp
33:24 Scale & Amp as attenuators or VCAs
33:41 Modulating modulation depth with VCA and making the classic fading vibrato modulation
34:55 Using the MIDI / sequence inputs or controllers to create velocity dependent modulation depths
Clock, quantising, sequencing, function generator and oscilloscope
36:01 Building a quick sequence
36:32 Creating sequencer patterns, controlling the range and quantising
36:59 Gate pattern sequencing
37:18 Changing sequencer step length
37:52 Clock 1 - a bonus LFO!
38:32 Clock 2 - with modulatable clock multiplication
38:45 Clock 2 - freeze / on/off control
39:31 Using the lag processor with modulated clocks for complex LFO shapes
40:05 Sequencer reset
40:28 Sequencer Curve output as a modulation source
41:03 Using an offset to transpose a sequence
41:39 Quantizer 2 - quantising LFOs for arpeggios
42:03 Function generator overview
42:26 Sample and hold S&H - making stepped random voltages
42:47 Sample and hold - LFO inputs for stepped LFO movement
43:16 Min/Max for audio processing
43:55 Onboard FX - building a sequence to demo the FX
44:44 DON’T FORGET THE OUTPUT MIXER!"
DigitalNativeDunce
I thought this sounded so cool that I bought Reason to get it!
Luap
Top work on the vid Ben! thumbs up
ben_hex
DigitalNativeDunce ah cool, enjoy it.
Thanks Luap
KittenVillage
I was going to pick up Complex -1. Low CPU usage on it. Really loved DivKid's vid. But then I've got so much already invested in Reason that I just couldn't pull the trigger on this one. Not even rent to own.
I decided to build my own.
Effects first, maybe Clouds, and an Ear unit for input. Tie it into another computer with an old Balance (audio interface from Propellerhead) so I can record.
Yeah, something about it made me go "screw this, I'd rather own the hardware."
So here I am.
Not giving up on Reason -- I hope to have some Refills for sale this year -- and I'm pretty passionate about that DAW. But yeah, Complex-1 made me want hardware.
Wonder where I can get some of those Propellerhead branded patch cables they had at Superbooth last year?
Luap
So here I am.
Really? You can replicate Complex 1 with 2 computers, an old balance interface, Clouds, and 'an ear unit' ? Are you modulating one computer with the other computer?
Please, do explain how cool
(Or are you, as I suspect, just shit posting all over the forum because you you have something to sell and you couldn't care less about littering the place with inane drivel)
KittenVillage
So here I am.
Great gatekeeping there, Luap. I do not have anything to sell. I am just starting out in Eurorack, and yes I would like to see the marketplace here. To buy, perhaps. I can't get there without participating though.
Hold on, bear with me. I know, I'm just a shitposting newbie to you. I'm not going to quote Rick Astley, but I am no stranger to the internet and I shouldn't volunteer more information for you to misinterpret. But I'm going to let you know where I'm coming from regardless.
FWIW, I think you misunderstood my post about Complex -1. I did not say that I could replicate it with two computers. (Though I'll add -- snarkly -- that maybe you could if one was running VCV Rack.)
I have another computer next to my electronics bench that hasn't been used much except to program an arduino a couple of years ago. That's the one that's going to be next to my new eurorack case and modules with my old balance interface to record with Reason. (And yes, I actually have two Reason licenses as well.)
But I do not intend to replicate Complex-1. What I meant in my post is that, in the parlance of the ex-mormon or ex-JW forums on reddit, Complex-1 'broke my shelf'. That is, I've been such a devotee of Reason (since Dec 2000) that I've always felt that investing deeply in hardware isn't quite worth it to me. I'm so into Reason that I've got 335+ rack extensions on my main account. (Admittedly that's because since they came along I am making enough money and can finally afford them.) I've always been more of a software guy than a hardware guy.
And one of the things I deeply love, having spent a lot of time coding for it, is the system Reason uses to tie in midi controllers into itself using LUA. I've actually gone on a weird binge the past couple of years buying controllers and I've got 5 or more that I picked up and don't use (because I haven't written interfaces for them.) And also yes, Reason has midi learn and such, and I could hook them up if I had more desk space...
The point, going back to Complex-1, is that I think a lot about interfaces on software synthesizers and how to tie them into midi hardware. My Nektar p4 has it's little screen, my Novation SL mk2 has automap on screen though automap hasn't been updated since Reason 6, I think. There's a great remotemap for the BCR2000 but you'd want to print out a stack of overlays just to follow what each dial is controlling for the different rack extensions. So you see, I've put a lot of thought about the interface on screen -- all those 300+ rack extensions I've got -- and how to tie them into all this midi gear.
Which brings me back to Complex-1 and why it "broke my shelf". Made me totally say 'fuck spending $100, I'd rather spend 10 times that and have hardware. (Or rather, start the process of having hardware.) It's those damn front wires. Yes, I know, many rack extensions have modulation grids, and those aren't midi assignable. It's not like Propellerhead can assign midi to each of those wire points, it's just not in the design of the thing. And yes, you can assign all the knobs to midi. But something about that interface, what it is trying to be...
And don't get me wrong. It succeeds. It's lovely, low CPU usage, too. You can, and I did during my trial of it, pack 8 of them in a combi and they sound great and did I mention CPU light? Lovely bit of code Propellerhead, as always.
Maybe for me, also, watching DivKid's video made youtube's algorithm spit out more eurorack videos at me, but honestly I was watching plenty synth vids already. I was all set to buy Complex-1, but I kept putting it off until it hit me that I didn't want to emulate, I wanted to piece it together myself. So, for me, the thing I want to try first is getting an MI Clouds and an MI Ears and putting them into a rack so I can play my guitar through it. Then I can add things each month, as my budget allows. But I think I'm done spending money on Reason for a while.
It does feel like dropping out of a religion and having your first cup of coffee and I'll be damned but that shit is good. And I think I'll fire up the soldiering iron in a few weeks and do some DIY modules.
So I know this is is a novella, but I wanted you to know where I'm coming from. I know you trolled out at me Luap, and here I am giving you plenty of personal data to troll more. But maybe we could just keep it to you saying 'littering' and me saying 'participating'. Do I really need to break out the Rick Astley at you?
Rigo
You can ... you just can't start new posts in the BST before you have 100 posts.
So buying is no problem.
But in defence of Luap, it wouldn't be the first time that people do a lot of irrelevant posting and then post 101 is in the BST forum.
KittenVillage
That's weird, I'd swear that for the past week I kept getting a message that I couldn't even look at the BST forum until I'd made 50 posts. But I guess that was the members only forum. I guess all I can say in my defense is that I've got a LOT of tabs open while I do research into things.
So my apologies. I hope you don't find all my posts to be shitposts.
Phitar
Re: Complex1... Looks neat but will they be adding additional modules to expand what is there? Or is that Complex-2? meh
