Best EQ plugin
Author Best EQ plugin
DT
Sounds like a noob question but what's your fav EQ plugin out there?
I use Logic Pro X, the built in one is quite good / simple
What about your go-to EQ?
UAD? Slate? FabFilter seems interesting with that "solo" button on the frequency you cutting / adding
Nice one and happy 2019 ya'll
jimfowler
If I have to use a plug-in eq it’s fabfilter.
ngarjuna
Acustica Pink for broad cuts and boosts: the combo of the included units (550a, 550b, 5500 & some vintage CAPI I barely use) and easy UI make it a quick way to get great sounding broad moves in a hurry. I mix for a living so I’m eq’ing pretty much all day long and Pink is my go to for sound and speed. The low shelves (killing proximity effect) and presence (3khz) are usually my biggest problem areas and Pink makes really fast work of those cuts while still sounding terrific.
TDR Nova for subtle cuts and boosts: if I have to get surgical with the Q or worry about blending I usually grab for Nova. The parallel action can keep things gentle while the UI and feature set make it easy to zero in on stuff and fix it with minimal intrusion. Has the solo per band, spectrum analyzer, dynamic eq. Very advanced and transparent.
ETA: somehow I neglected to mention that Nova is FREE!
Honorable mention to the Sie-Q from Soundtoys which is another great example of a great sounding EQ that makes very fast work of eq’ing.
One thing I’ve learned is that for me, when it comes to EQs, more features just get in the way more. It’s rare cases that require special features so I reserve my use of such devices for the cases where they’re needed.
Tunatoboggan
I really like the Sonnox EQ for 90% of use cases. Quick and clean, easier on the eyes than Avid EQ III
It doesn't have a spectrum analyzer though, so for that I like the Ozone EQ. You can do the fabfilter band solo thing too. Even lets you see the changes in phase, very handy
Chevron87
You have to try the Fabfilter Pro-Q3, for most EQ jobs it covers eveything and also very good for mastering Linear Phase mode. Plus all the extras like a good spectrum analyser, EQ match, tilt curve, extreme slopes, M & S, level match and now dynamic EQ as an option too..
I also really like the Brainworx EQ V3.
For more of an analog sound I really like the Softube E & K Series SSL.
martinjuenke
The EQs (LinearPhase, Vintage) in LogicPro are covering all you need. I would not buy something additional. The money can be used for something more useful...
cretaceousear
As a Reaper user I'm fine with the built in Cockos Eq for most things - I also use Nova sometimes.
Not mentioned yet is the free http://photosounder.com/splineeq/ SplineEQ by Photosound - lets you draw the curve with er.. splines.
It can do very sharp cuts and has a groovy colour based spectrum display - useful for surgical removals and nice to look at.
Linear phase if that's important to you. Free version is 4 band - paid for up to 60.
mritenburg
This is good advice. Knowing the difference between transparent (linear phase) and colored (vintage) EQ's and how to use them is more important than having any one "go to" EQ.
DT
Both great advices.
Incredible I wasn't even aware of the Vintage EQ series in Logic!
Sometimes solution is under your nose.
Would be great if you could explain me difference between linear and colored?
Maybe linear is more suitable to "remove" frequency and vintage to "add"?
induktor
Agreed. For mastering I generally use my hardware EQ's but the Pro Q is great for surgical stuff. I've been using the Pro Q 2 for quite a while and just picked up version 3.
Panason
For me this ends up applying to all plugins. If I'm presented with a crapload of controls, tiny buttons (often unlabelled) , drop down menus, tabs, back panels etc... i end up simply not using that plugin.
Mantaray
I also like Fabfilter Pro Q, all the features and visual feedback make it indispensable.
chvad
Voxengo Gliss. It's basically the only EQ I use anymore.
Mantaray
This one slipped under my radar. Will check it out, looks very cool. Have you compared it to Fabfilter Pro Q 3 which also has dynamic EQ?
chvad
ive never used the fab eq so its hard to compare. i have the fab saturn and i think fab has the better GUI in some cases in general but under the hood... the voxengo stuff does a lot for me.
Chevron87
You know you most likely can do a lot with the Logic stock plug ins, and I am a big fan of using proprietary plug ins - but I find the tactile nature of Pro-Q3 and range of cool features makes the cost well worth it. It's also great that I can sue the same EQ across different DAWs.
TXBDan
Cubase has good channel strip EQs and even the FrequencyEQ (very FF Pro-Q-like) is solid, but i STILL got FF Pro Q because the UI is so good.
I like in Pro-Q3 how you can monitor the spectra of all the EQs in use and it highlights hotspots, etc.
tuttlerecall
I would recommend using a range depending on the use. I like using something like Fabfilter to strip away unwanted frequencies but also use something with analog emulation to add character.
Fabfilter like everyone has mentioned is a good choice for a modern surgical EQ, it has a very good interface.
Softube's tube tech and the sie-q in soundtoys is also great. These emulate different analog EQs.
DMG's EQuilibrium combines both of these in one plugin. You can mix and match different techniques with different analog emulations on each band if you like.
Chevron87
Wise words. I use Fabfilter for cleaning up and shaping sounds, then more 'analog' style for adding character or weight, cripsness, bite etc
DJMaytag
Fabfilter Pro-Q and Maag EQ4 are my most used EQ’s.
josaka
no mention for the DMG Equlibrium... ?
sounds very close to my hardware..
Chevron87
There was a time when DMG Equlibrium was battling with Pro-Q V1 for users, I demoed both and came away with Pro-Q only because the interface seemed marginally more intuitive. I know there have been some updates sonce then on Equlibrium so I may revisit as I really like DMGs plug ins.
chiavere
+1 to both of these - also my most used eq plugins. All the fabfilter stuff is great, super functional, and the best GUI in the business, for my taste.
