MIDI on Intellijel case as breakout for fh-2?
Author MIDI on Intellijel case as breakout for fh-2?
visible cow
I'm curious if anyone knows if there's a way to connect the MIDI DIN on the Intellijel cases to the fh-2 (instead of buying the breakout from Expert Sleepers)? It would be great to put those midi connections to use.
ndf
Yes. Directly. Connect the pins on each header as follows:
expert sleepers - Intellijel case - function
1 - 3 - OUT pin 4
2 - 4 - OUT pin 5
3 - 2 - IN pin 5
4 - 1 - IN pin 4
Hope that helps smile
manglepup
Check out my thread here for using the intellijel case midi din "out" port (which is not wired up by default) as a din midi in port for the FH-2.
https://www.muffwiggler.com/forum/viewtopic.php?t=209040
visible cow
Excellent info, thanks!
visible cow
One quick question as I've never done this before. Are these the cables I'll need?
