FH-2 - Logic Pro X Sync
Author FH-2 - Logic Pro X Sync
ziovinos
Is there a way to control logic's tempo with FH-2's encoder button??
You mean directly, or by syncing Logic to the FH-2's MIDI clock?
ziovinos
I meant directly yes. Like assigning logic's tempo to FH-2's encoder button for real-time adjustments.
Syncing Logic to the FH-2's MIDI clock and vice versa, is a good question that came out these days too.
There's something else: When I have my midi keyboard -it's an Akai MPK Mini mkII- connected to the FH-2's USB A socket, I can't upload (but I can send) data from FH-2 via the browser-based Configuration tool. To do that, I have to unplug, upload and replug.
You mean the 'Upload from FH-2' button doesn't work? Just nothing happens?
ziovinos
Yes, if my midi keyboard is connected to the FH-2's USB A socket the 'Upload from FH-2' button doesn't work. The current configuration doesn't appear. To make it work, I have to unplug first, 'Upload from FH-2' (that's when "current configuration" shows up) and then plug the keyboard again.
How odd. Are you on the latest firmware (v1.4)?
ziovinos
Yes
