nonlinearcircuits 2019 modules
Author nonlinearcircuits 2019 modules
andrewF
GENiE - this is a triple neuron with connections between the 3, shared inputs and a diff-rectifier
Digital filter simulator - this is an analogue circuit designed to simulate a canonical digital filter.....badly
Spasm - takes a classic Sprott jerk chaos circuit and replaces all the resistors with LDRs...what could go wrong? It uses the NLC blackbox method, so no need to buy any vactrols.
Signum Hyperchaos - this is an expanded version of the NLC Primal Hyperchaos with the signum switch brought out to the front panel. It means there are now 2 different modules in one, or you have a lot of new ways to interfere with the hyperchaos.
Eric the Red
Starting the year off strong! Can’t wait to see what else you bring out.
cackland
Nice work Andrew, now on my radar!
Blingley
Okay, I really want an audio demo of that filter module. lol
synthpriest
Any more modern takes on ancient stuff like you did with the Aries 329? hyper
andrewF
Shat Noir? hihi
uuav
I guess the next evolution is a Neuron Matrix smile
mosheen
Using the headers for a light box on Spasm is genius!
OIP
woo!
that filter is going right next to the bi-n-tic
thetwlo
ridiculous!!!! Amazing! we're not worthy we're not worthy we're not worthy we're not worthy
andrewF
Blingley
I love it. applause
n0rd
NLC Digital Filter Simulator Demo:
https://soundcloud.com/subconsciousinclination/nlc-digital-filter-simu lator-demo
[soundcloud url="https://api.soundcloud.com/tracks/553523982" params="auto_play=false&hide_related=true&show_comments=true&show_user =true&show_reposts=false&visual=true" width="100%" height="300" iframe="true" /]
0:00
Noise --> Digital Filter Simulator (DFS) IN.
Kareishuu VCO Square --> DFS Clock.
First raw noise then output then through DFS.
Manual sweep of DFS Range, Feedback and Kareishuu Freq pots.
0:47
Plague of Demons (PoD) Tri & Saw --> Mixer.
Plague of Demons (PoD) Square --> Divide & Conquer IN.
Divide & Conquer /2 --> Mixer.
Mixer --> Digital Filter Simulator (DFS) IN.
First, mixer raw output then through DFS.
Manual sweep of DFS Range and Feedback pots.
1:52
3:05
CEM 3340 Pulse + Saw --> Multifilter --> VCA --> OUT & EFX send (delay).
Digital Filter Simulator (DFS) in delay feedback loop.
Env --> VCA & Filter.
Dixie II --> DFS Clock.
LFO --> DFS Range.
First dry (no EFX) then delay without DFS then with DFS.
Manual tweaking of Filter freq, res EFX send & EFX level.
4:23
Drums --> Env Follower --> Digital Filter Simulator (DFS) IN.
Env Follower ENV --> Kareishuu VCO FM IN.
First drums raw then through DFS.
5:15
CEM 3340 Tri & Saw --> Mixer.
CEM 3340 Sine --> Timbre & Timbre --> Mixer.
CEM 3340 Pulse --> Offset --> Divide & Conquer IN --> /2 --> Mixer.
Sequenced with Korg SQ1.
Mixer --> VCA -->Digital Filter Simulator (DFS) IN.
Added EFX (delay).
6:30
Sheep (Bi, Sub & 1-bit) --> Mixer1.
Mixer1 --> Digital Filter Simulator (DFS) IN and Main OUT.
DFS Out --> OUT & EFX send. (Reverb pedal effect).
CEM 3340 Square --> Invy (offset) --> DFS Clock.
LFO1 & 2 --> Sheep Row & Col.
LFO3 --> DFS Range.
LFO4 & 5 --> CEM 3340 Log FM & Linear FM.
Manual tweaking of Sheep (dry), DFS, EFX send & EFX level.
Steve
andrewF
Crikey thumbs up
Thanks Steve!
andrewF
andrewF
andrewF
n0rd
NLC GEneralized Nonlinear Extrapolator Demo:
https://soundcloud.com/subconsciousinclination/nlc-genie-demo
[soundcloud url="https://api.soundcloud.com/tracks/554012982" params="auto_play=false&hide_related=true&show_comments=true&show_user =true&show_reposts=false&visual=true" width="100%" height="300" iframe="true" /]
0:00
Kareishuu VCO Tri --> Genie IN1 top.
Plague of Demons 01 Sine --> Genie IN1 btm.
Plague of Demons 02 Sine --> Genie IN1/2 btm.
CEM 3340 Tri --> Genie IN1/2 top.
Genie OUT1 --> Out.
Two VCOs (then more) into Genie.
Manual tweaking of Sense, React and IN1 pots.
Plus manual tweaking of each VCO freq/pitch.
Also changing of VCO output types eg Tri to Saw etc.
1:52
Plague of Demons Pulse & Saw --> Mixer.
Plague of Demons Square --> Divide & Conquer --> /2 --> Mixer.
CEM 3340 Saw & Pan Pulse --> Mixer.
Sloths --> Plague of Demons & CEM 3340 PWM.
Mixer --> Serious Filter --> Out.
LFO1 Saw --> Genie IN1/2 top.
LFO2 Tri --> Genie IN2 btm.
LFO3 Sine Genie IN2/3 top.
Genie OUT2 --> Serious Filter CV.
Raw Mixer --> Filter heard first.
Next LFOs are routed to filter CV directly, one at a time then together.
Next LFOs are routed via Genie (as described above), one at a time, then pairs then all three.
(LFO1, LFO2, LFO3, LFO1+2, LFO1+3, LFO2+3, LFO1+2+3)
Note: LFOs do not change speed - changes in patterns come from Genie!
Manual tweaking of Sense, React and IN pots.
3:44
Drums --> Out (mono).
Drums --> Genie IN2 top --> Genie OUT2 --> M/S --> Out Lieft/Right. (Fades in).
4:54
Plague of Demons 01 Tri --> Genie IN2 btm.
Plague of Demons 02 Tri --> Genie IN3 btm.
CEM 3340 Tri --> Genie IN2 top.
Genie OUT1, -, + 3 --> VCAs 1, 2, 3 & 4.
Envs --> VCAs.
VCA1 & 3 --> Out Left.
VCA2 & 4 --> Out Right.
Added EFX (modular delay and compressor).
7:04
Elements L/R --> Genie IN1/2 & 2/3 top.
Elements L/R --> Out Left & Right.
Sloths --> Elememts.
Env1 --> Genie IN1 btm.
Env2 --> Genie IN3 btm.
Grids --> Elements Gate, Env1 & Env2.
Genie Out 2 --> Out (mono).
Out --> Pedal EFX (reverb) + sample.
w00t
Steve
n0rd
NLC Spasm Demo:
https://soundcloud.com/subconsciousinclination/nlc-spasm-demo
[soundcloud url="https://api.soundcloud.com/tracks/554447001" params="auto_play=false&hide_related=true&show_comments=true&show_user =true&show_reposts=false&visual=true" width="100%" height="300" iframe="true" /]
0:00
Plague of Demons 01 Saw --> Mixer.
Plague of Demons 02 Saw --> Mixer.
Mixer --> Feague --> VCA --> Out.
Spasm OUT1 --> VCA CV.
Spasm OUT2 --> PoD01 PWM.
Spasm OUT3 --> PoD02 PWM.
Spasm OUT4 --> Feague CV.
Clock --> Spasm Inject CV.
Each Spasm OUT starts muted.
First OUT2 & 3 unmuted.
Then OUT4, then OUT1.
Manual tweaking of Spasm Freq, Feedback and Inject pots.
1:57
Plague of Demons Pulse + Saw --> Mixer.
Mixer --> Serious Filter BP --> VCA --> Panner --> Out.
Spasm OUT1 --> PoD PWM.
Spasm OUT2 --> Pan CV.
Spasm OUT3 --> VCA CV.
Spasm OUT4 --> Serious Filter CV.
Clock --> Env --> Spasm Inject CV.
3:40
Plague of Demons Saw + Pulse --> Mixer.
Mixer --> Serious Filter --> VCA --> OUT Left.
Mixer --> Doepfer A106-5 SEM Filter --> VCA --> OUT Right.
Env --> Spasm Inject CV. (First muted).
Spasm OUT1 --> Serious Filter CV.
Spasm OUT4 --> Doepfer A106-5 SEM Filter CV.
5:08
NE Loquelic Iteritas --> VCA --> DLD --> Out.
Mutant Bassdrum + Hihats --> Out.
Spasm OUT1 --> LI Morph.
Spasm OUT2 --> LI Damp.
Spasm OUT3 --> LI Fold.
Spasm OUT4 --> LI Mod.
Clock --> Env1 --> Spasm Inject CV.
Out --> Streams (compressor).
Dead Banana
Steve
n0rd
NLC Signum Demo:
https://soundcloud.com/subconsciousinclination/nlc-signum-demo
[soundcloud url="https://api.soundcloud.com/tracks/555818784" params="auto_play=false&hide_related=true&show_comments=true&show_user =true&show_reposts=false&visual=true" width="100%" height="300" iframe="true" /]
0:00
Plague of Demons 01 Tri --> Timbre & Timbre --> Mixer.
Mixer --> Feague VCF --> Panner --> Out.
Signum X --> PoD1 PWM.
Signum Y --> Feague CV.
Signum Z --> Pan CV.
Signum invZ --> Timbre & Timbre CV.
Signum Gate --> Peaks (Kick).
Manual tweaking of Signum Climax and Bifircate pots.
0:54
Signum Gate --> NLC Balter.
Signum Gate + (or) Balter OUT1 --> NE Basimilus Iteritas Alter Trig.
Signum Gate --> NE BIA Attack.
Signum X --> NE BIA Morph.
Signum Y --> Fold.
Signum Z --> S/H --> NE BIA Pitch.
Signum inv Z --> Balter CV1.
Signum W --> NE BIA Harm.
NE BIA --> Delay --> Streams (Compressor) --> Out
1:46
Plague of Demons 01 Saw --> VCA1 --> Filter1 --> Delay --> Left.
Plague of Demons 02 Saw --> VCA2 --> Filter2 --> Delay --> Right.
Kareishuu Sine --> PoD1 & 2 Ext Mod.
Signum X --> VCA1 CV.
Signum Y --> VCA2 CV.
Signum Z --> Filter1 CV.
Signum inv Z --> Filter2 CV.
Signum W --> PoD1 & 2 FM Env.
Signum Gate --> Seq Clock.
2:36
Kareishuu Tri --> Timbre & Timbre IN1.
T&T Out1 --> T&T In2.
T&T Out2 --> M/S delay --> OUT.
LFO1 Tri --> Signum IN1.
LFO2 Square --> Signum SW2.
Signum X --> T&T CV2.
Signum W --> T&T CV1.
3:19
Plaits --> Clouds (delay) --> OUT.
Signum X --> Plaits Timbre.
Signum Y --> Plaits Morph.
Signum Z --> Shades --> Plaits Harm.
Signum W --> Clouds Texture.
Signum Gate --> Plaits Trig.
4:05
Plague of Demons 01 Tri --> VCA1 --> DLD --> OUT.
Plague of Demons 02 Tri --> VCA2 --> DLD --> OUT.
CEM 3340 Pan Pulse --> VCA3 --> Filter1 --> Delay --> OUT.
O&C (1V/oct) Out1, 2 & 3 --> PoD1, Pod2, CEM.
Signum X --> Shades --> O&C CV1.
Signum Y --> Shades --> O&C CV2.
Signum Z --> Shades --> O&C CV3.
Signum inv Z --> Filter CV.
Signum W --> Comparator --> O&C Trig3 and Env3 (to VCA3).
Signum Gate --> Branches.
Branches OUT1 --> O&C Trig1 and Env1 (to VCA1).
Branches OUT2 --> O&C Trig2 and Env2 (to VCA2).
Sloth --> CEM Pan PWM, Env3 decay.
Dead Banana
Steve
geecen
Great modules and great demos as usual Steve. That digital filter simulator sounds amazing.
