FH-2 : X input issue
Author FH-2 : X input issue
Sebdaflou
Hi,
Recently, The X input seems not to work.
When i use it as a tuner, it doesn't recognize anything...
I tried to flash and reboot it without success.
Any recommandations ?
Thanx
Seb
Have you tried 'Test inputs' from the Misc menu?
Sebdaflou
ok, just tried, nothing happens..
Values float around about 68/73, the line is straight.
i tried to insert VCO output and LFO.
Is it a hardware problem ?
It could be, yes. Does the LED on the input socket react?
Sebdaflou
nop....
Hmm - sounds more like the socket is faulty. How about the Y input?
Sebdaflou
It's the same for the Two inputs, i didn't try it before as i discovered the issue by trying to use the tuner.
Do you think i'll have to return it for repair ?
Sounds like it, yes. Email me we'll sort it out.
