The 2019 Show Us Your DIY Builds Thread
Kampfzwerg
Post by Kampfzwerg » Thu Aug 15, 2019 1:30 am
First SEM Clone Prototype is working now.
Still waiting for the VCO Frequency fine Potentiometers to arrive.
WOMEN AND CATS WILL DO AS THEY PLEASE,
AND MEN AND DOGS SHOULD RELAX AND GET USED TO THE IDEA.
mome rath
a dubious cube of margarine
Post by mome rath » Thu Aug 15, 2019 8:15 am
ooooooooooooooooh myyyy
soundcloud, dear friends
good trader cred
instagraM
guest wrote:
Fri Jan 03, 2020 2:45 pm
basically, as the dude put it "no walter, youre not wrong, youre just an asshole".
zoogoo wrote: your stupid
Roni
Post by Roni » Thu Aug 15, 2019 9:33 am
My first 0402 build. I was surprised I could do them by hand.
Kampfzwerg
Post by Kampfzwerg » Thu Aug 15, 2019 12:17 pm
Wow, these solder joints look very clean. Good job!
paperCUT
Post by paperCUT » Fri Aug 16, 2019 1:55 pm
paperCUT wrote:I finally fixed the last few issues with this :) It's a conversion of the utterly fantastic RV600 and EM600 pedals. Each of the boards had their pots and jacks removed and a carrier board made for each (same board). Then using the multi row headers and the SMD jumpers each board get it's 'address' on the front panel board. The system worked really well but it proved to be practically impossible to removed the large electros so the headers had to extra long and crudely cut down :waah: Not skiff friendly!
In case anyone is interested I'll attach the schematics for these pedals so they don't get lost. They differ slightly between models but the signal path is basically the same, it's very clean 8-)
I can share my eagle files if anyone dares to try mounting both :hihi:
chuckg
Post by chuckg » Fri Aug 16, 2019 1:58 pm
So happy to be posting my first real build, a Module Toaster/Tester/NotFromMu device. I forgot how zen it is to sit and solder! I really must tell an embarrassing tale of this build. I put it together, sans chips, and fired it up for voltage checks. Then I put in the chips and fired it up again. To my horror, there was nothing on the display. I checked everything.... seemed fine, but still no text on the display. Then I realized, no, DUHHHH, try adjusting the contrast! Stupid me.
Another Stupid Mistake came about when I clicked the rev1 BOM instead of rev2. That's why you don't see the DC-DC inverter, and instead see cables from a pair of 12VDC wall warts. Not stupid if it works! I'll either get the inverter, or just build a +/- supply from the rev1 parts.
I'll knock together a case in my wood shop over the weekend.
….working on it.
cartertools
Post by cartertools » Wed Aug 21, 2019 2:42 pm
Another 2x84hp case, I'm really going to rearrange all my modules while I have the space before I build more...just like I thought I was going to the last case I built. Finally made a jig for cutting/drilling the vector rail angle brackets on the CNC, which made setup a lot easier. Busboards designed in Kicad and made by JLC. Went a little crazy with the paint job.
Kampfzwerg
Post by Kampfzwerg » Wed Aug 21, 2019 3:28 pm
chuckg wrote:So happy to be posting my first real build, a Module Toaster/Tester/NotFromMu device. I forgot how zen it is to sit and solder! I really must tell an embarrassing tale of this build. I put it together, sans chips, and fired it up for voltage checks. Then I put in the chips and fired it up again. To my horror, there was nothing on the display. I checked everything.... seemed fine, but still no text on the display. Then I realized, no, DUHHHH, try adjusting the contrast! Stupid me.
Hey there chuckg:
About those dumb mistakes: It happens to all of us! I mean it. really stupid stuff. Anybody who is telling you otherwise is just lying. Simple as that...
chuckg
Post by chuckg » Wed Aug 21, 2019 6:07 pm
Kampfzwerg wrote: Hey there chuckg:
...it's all part of the fun! Without dumb mistakes there would be no Teflon. Literally.
….working on it.
dot matrix madness
Post by dot matrix madness » Fri Aug 23, 2019 2:51 am
TR 909 bass drum clone with four additional potis for modifications (right hand row) plus manual trigger button. Compression turned out to be
rather subtle, but Depth, Pitch, and Distortion rock.
Specs: 12HP, powered from +/-12V, main PCB is 8cm deep, the three ICs of the noise source plus the filter network are on the sub PCB.
Licenced to solder since 1993
mrtweed
Post by mrtweed » Thu Aug 29, 2019 11:55 am
Just built a couple of those cute baby sloths.
cartertools
Post by cartertools » Fri Aug 30, 2019 11:13 pm
Quick test circuit for measuring amps on both rails at the same time.
Image[/img]
aphantomvaper
Post by aphantomvaper » Sat Aug 31, 2019 8:11 am
mrtweed wrote:Just built a couple of those cute baby sloths.
I didn't even know those existed! Gotsta get some of those!
The only thing that stays the same is change
retoid
Post by retoid » Sat Aug 31, 2019 10:32 am
Nice! I built a few of them as well :D
Looking forward to Andrew's latest 1U modules also.
Synch59
Post by Synch59 » Wed Sep 04, 2019 1:06 am
The result of 4+ months of researching, sourcing parts, building, and troubleshooting.
Tiptop Audio Happy Ending w/ uZeus PSU
LMNC 3340 VCO
AISynthesis AI002+ (added another input)
LMNC MS-20 style LPF
Dintree D100 Quad VCA
JJ Clark's AS3310 ADSR (still troubleshooting)
Yet more to discover and build.
DIYDSP
64-in-1 Analog Knob Input Multiplexer
Post by DIYDSP » Wed Sep 04, 2019 9:11 am
It got so painful dealing with a dearth of analog inputs on micros to make knobs... So I finally designed one daisy-chainable multiplexer to rule them all!
My system should scale to 8 boards with 5 built-in knobs each and additional inputs for 3 more. That makes 64 knobs in total. It only uses one analog input on an Arduino/Teensy/Nucleo/ESP/etc. It also uses two digital outputs. I've been documenting the process on yt and getting feedback from people.
64-in-1 Synthesizer Knob Multiplexer
ashleym
Re: 64-in-1 Analog Knob Input Multiplexer
Post by ashleym » Wed Sep 04, 2019 4:01 pm
DIYDSP wrote:It got so painful dealing with a dearth of analog inputs on micros to make knobs... So I finally designed one daisy-chainable multiplexer to rule them all!
Thanks for posting. I just watched some of the related YouTube videos. Clear and informative (that’s a lame way of saying good). This stuff isn’t complicated if (a) you know what you’re doing (b) creative (c) you understand it well enough to explain it well.
J3RK
Post by J3RK » Fri Sep 06, 2019 12:15 pm
In progress... :banana:
Bartelby
Post by Bartelby » Fri Sep 06, 2019 12:41 pm
I haven't built much over the last 6 months. But today all the parts arrived for me to build:Image
Now I just need to find the Amazon Echo power supply, that's in a drawer somewhere...
cygmu
Post by cygmu » Fri Sep 06, 2019 12:44 pm
J3RK wrote:In progress... :banana:
But what is it you big tease?
Nice to see you back designing and building!
J3RK
Post by J3RK » Fri Sep 06, 2019 1:07 pm
:hihi:
I'll have something more substantial to show very soon with some details.
Jay F.
Post by Jay F. » Sun Sep 08, 2019 5:58 am
I just finished a Turing Machine.
Image Image
"We are born naked, wet and hungry. Then things get worse."
https://growyoursynth.blogspot.be/
Lolo73
Post by Lolo73 » Sat Sep 28, 2019 10:05 am
I am starting a series of simple but useful modules: mixer, crossfader, etc. Here are my first front panels (still searching for a good design) and my first module. For the moment, nothing documented, but I'm working on it!
gnsk
Post by gnsk » Sun Sep 29, 2019 4:16 am
"Stziopa x Bastl: Kompas"
* from open-source schematics and code
* 5hp -> 4hp repackt
dot matrix madness
Post by dot matrix madness » Sun Sep 29, 2019 4:44 am
I admire people that have the guts to refrain from using PCBs and solder directly to ICs.
