The 2019 Show Us Your DIY Builds Thread
Lolo73
Post by Lolo73 » Sun Sep 29, 2019 12:15 pm
dot matrix madness wrote:I admire people that have the guts to refrain from using PCBs and solder directly to ICs.
Yeah ! :yay:
Grumble
Post by Grumble » Sun Sep 29, 2019 1:16 pm
You should check THIS guy out :hail:
Lolo73
Post by Lolo73 » Sun Sep 29, 2019 1:26 pm
Grumble wrote: You should check THIS guy out :hail:
Yes... Or this one : Peter Vogel One of my prefered artist
Pixelator
Post by Pixelator » Sun Sep 29, 2019 2:45 pm
soup wrote:Moogah SEM filter...
Hexinverter Postman EG...
Stroh Stereo Out...
It's a banana frac party :banana: :nana: :bananaguitar:
Where did you get those colorful jack sockets? :D
dot matrix madness
Post by dot matrix madness » Mon Sep 30, 2019 4:08 am
There is a 20m tall installation of Peter Vogel (1937-2017) in the Max-Planck Institute in Saarbruecken (Germany), which is next to my office. What coincidence!
Licenced to solder since 1993
av500
Post by av500 » Mon Sep 30, 2019 4:10 am
Pixelator wrote: Where did you get those colorful jack sockets? :D
looks like the banana jacks that Mouser sells
Lolo73
Post by Lolo73 » Mon Sep 30, 2019 7:20 am
dot matrix madness wrote: There is a 20m tall installation of Peter Vogel (1937-2017) in the Max-Planck Institute in Saarbruecken (Germany), which is next to my office. What coincidence!
Nice ! have you ever seen it in real ? I'd like to !
dot matrix madness
Post by dot matrix madness » Wed Oct 02, 2019 6:47 am
I know this installation since 2003 and was pretty impressed by its size. It is in the hall of that institute and you can have a look at it during business hours. There are more buildings on the campus that have art as part of the construction, which are open to the public.
Unfortunately they turned off the sound (which isn't that impressive), but you can still see the 300 LEDs starting to react if you come close.
OIP
Post by OIP » Thu Oct 03, 2019 12:25 am
gnsk wrote:"Stziopa x Bastl: Kompas"
amazing!
just having a look at this module, seems cool like free range grids
muncky
Post by muncky » Fri Oct 04, 2019 8:52 am
Just about finished calibrating Slopey - panel from Loudest Warning, built by me. Lots of help from Cygmu and thebadproducer for the funkier mods and calibration routines. The recreation of the Model 14 did take a lot of brain power but initial findings very positive. :guinness:
Favourite addition is the Cycling jack on the DTGs, which causes them to cycle when a gate is received.
Must continue to work on my wiring tho - this one is pretty dense, and I’m sure I can continue to make this tidier!
J3RK
Post by J3RK » Fri Oct 04, 2019 10:42 am
Nice work! I really like the standoffs for working on the back. I've never done that, but I'm about to start! :yay:
muncky
Post by muncky » Fri Oct 04, 2019 11:01 am
J3RK wrote:Nice work! I really like the standoffs for working on the back. I've never done that, but I'm about to start! :yay:
Thanks! It was actually a nightmare of adjustments throughout to get it all to fit, made worse by the idea/need to use chicklets for the Model 14 at the 11th hour. Modular Tetris!!
chuckg
Post by chuckg » Sat Oct 05, 2019 12:36 pm
Hand-carved power supply board, $mumble
recently built, unenclosed module tester, $something
ancient Tektronix 475, $buckfiddy
working VCO1, saweeeet!
….working on it.
dot matrix madness
Post by dot matrix madness » Mon Oct 07, 2019 9:12 am
Submixer/adder (for analog drum modules that have their own level knob): 10 mono inputs, 1 output with gain control.
So far the first module where I made the front plate first for obvious reasons. 6HP, but possibly also doable on 4HP.
cartertools
Post by cartertools » Mon Oct 07, 2019 10:38 pm
CGS gate block inspired/derived quad gate boost/buffer. Takes a smaller gate and makes it 0V-9V. Image
dot matrix madness
Post by dot matrix madness » Thu Oct 10, 2019 5:35 am
Pimp your bass drum: ProCo Rat Distortion Pedal (schematics here) adapted to 6HP by combining it with the CGS stomp box adapter. Instead of 9V it works from +12V as well.
Addtional feature: Toogle switch between silicon diodes (1N4148) and germanium ones (AA134). The silicon diodes produce a somewhat brighter sound. Thus you might want to try diodes with even larger voltage drop, such as LEDs.
OIP
Post by OIP » Thu Oct 10, 2019 8:02 pm
got totally inspired by the kompas build in this thread (thanks!) so made one from stuff i had on hand. it's janky but hey it works and it's a cool little module, been having lots of fun with it. that arduino nano has been sitting in a drawer for months, get to work nano.
mome rath
a dubious cube of margarine
Post by mome rath » Fri Oct 11, 2019 10:09 am
thank you, this guy is amazing
it's a very clever way to build modules...
soundcloud, dear friends
good trader cred
instagraM
guest wrote:
Fri Jan 03, 2020 2:45 pm
basically, as the dude put it "no walter, youre not wrong, youre just an asshole".
zoogoo wrote: your stupid
AlanP
Post by AlanP » Fri Oct 11, 2019 5:12 pm
Had to get some panels made, but got it sorted. The Drive control is rather subtle, might be my ears, maybe.
According to Ken Stone, these 1J24B valves draw less power than a LED.
appliancide
Post by appliancide » Sun Oct 20, 2019 6:35 pm
Finally finished the second frequency shifter I started building early this year. The customer's was done over two months ago. I could have been done a bit sooner, but a couple of easy-to-build kits jumped the line.
Eric the Red
Post by Eric the Red » Wed Oct 23, 2019 3:11 pm
appliancide - that’s one sexy build.
Abandon all hope, ye who wiggle.
MikeDB
My Latest Additive Synth prototype
Post by MikeDB » Fri Oct 25, 2019 8:12 am
95% digital so possibly not of interest to all, but you can see some of what it does at
http://inposesynth.000webhostapp.com/
Fits a standard Eurorack provided it's not too slimline a case. Love to hear any comments at mikedbryant@live.com
I aim to add the ability for people to actually try the real hardware online but need to change broadband supplier so I can get a fixed IP address.
das_Produkt
Post by das_Produkt » Sun Oct 27, 2019 7:01 am
I just built my CGS Programmer/Sequencer.
The stage indicators are LED rings around the push buttons.
The picture quality is bad, again...
hox3d
Post by hox3d » Sun Oct 27, 2019 9:40 am
After a while, here is what I have so far.
Several modules working and a powered case with a power distribution.
I just need to build a small output module for headphones.
But I'm quite happy with the result for now!
PSU is from Elby design, and I used the bad producer's guide to build the case.
I wonder what to build next... I still have most of the MARSH PCBs left.
Matte-fueled habits
cygmu
Post by cygmu » Sun Oct 27, 2019 11:41 am
That boat is coming together very nicely.
What’s the power distribution board that you’re using? I don’t think I’ve seen those before.
