ES-8 Sync performance
Author ES-8 Sync performance
jackpf
Hi,
Im trying to figure out how to solve some issues with my setup - I'm currently using:
Ableton + ES-8
Safire Pro 24
I'm only using the Safire pro to get audio to my speakers, and the ES-8 is setup as an aggregate device.
Everything works well, but I get crackles and pops occasionally when recording and audio playback can get a bit erratic in Ableton. It seems to get worse when more CPU intensive stuff is going on in Ableton.
I assume its down to the aggregate device performance. I have:
Sample rate 44.1KHz on ES-8 and Safire
Clock source: Safire
Drift correction turned off
Is there a way to improve this setup, or any tips? If i had an interface with ADAT, would using a cable + ADAT sync improve things?
Many thanks for any help!
You will need to either
- turn on drift correction for the device which is not the master, or
- connect via ADAT and share the digital audio clock.
