That's what I am talking about:
viewtopic.php?t=20288&highlight=
These are fabulous looking, 7,5 cm high cases with 105 Hp, powered with the Flight of Harmony Power Module.
Power works as it should and is very easy to handle. Definitely an easy recommendation. As i live in Europe i had to find the right wallwart to go with, and this one does the job:
http://www.conrad.de/ce/de/product/5117 ... T-12VAC24W
The boats arrived very well packed and are not only nice to look at, but also nice to touch. They feel lightweight, but at the same time very solid.
The size of the provided sliding nuts is not so common here in Europe, so I exchanged them with M2.5 ones.
The bus boards are Modular World ones and are assembled to the upper left. Therefore remains enough place at the right for some deeper modules. I did not measure it exactly, but 4-5 cm deep modules should fit, where the boards are, and 6 cm deep modules at the right. Two or more boats could be easily put together with four screws for a 6U or 9U boat.
And this is how they look filled:
Bottom line:
And to Goiks:
It was very nice to discuss with him, how the boats should look and work at the end. I am proud that some of my thoughts went into the final design.
And it was absolutely a pleasure doing business with him. Thanks a lot!
