FH-2 - MPE Split Note Range - CC Issue
Author FH-2 - MPE Split Note Range - CC Issue
aberrant_devices
Hey!
I'm trying to setup my Roli Seaboard Block in MPE mode so the bottom octave (notes 0-11) outputs CV, Gate, Aftertouch, and Y (slide) CC to the FH-2 1-4 and the the rest of the key range (notes 12-127) outputs CV, Gate, Aftertouch, and Y (slide) CC out FH-2 5-8.
This almost works perfectly EXCEPT the Y CC parameter (cc #74) only works for one converter. It will work for both individually if the other is deactivated, but when both are active, only one of them works.
I've attached a screenshot of the configuration.
Thanks for your advice!
I think you found something I overlooked. I'll put that on the list to be fixed.
aberrant_devices
Thanks Os!
