EMS VCS3 mk2 dimensions anyone know?
Author EMS VCS3 mk2 dimensions anyone know?
sirg
I'm looking to build or get built a flight case for a VCS3 mk2. Does anyone know what the physical dimensions of the VCS3 mk2 are? I found the Putney ones in the user manual online, but I think the mk2 might be a slightly different size.
Any help much appreciated! Flamed!
papz
Even between MK2 units the dimensions may vary slightly. You should measure the actual VCS3 the flight-case will be made for.
sirg
Thanks unfortunately that's not possible as it's locked away overseas - hence the case to get it here smile but If I can get close to correct measurements I can add a bit of wiggle room and then have extra padding internally...
papz
Here are the largest dimensions of one that's here currently.
Height : 433 mm
Depth : 427 mm
Width : 442 mm
sirg
Height : 433 mm
Depth : 427 mm
Width : 442 mm
cheers thanks very much that's very helpful! Drinking
