Polychaining 2 Dreadbox Nyx?
Author Polychaining 2 Dreadbox Nyx?
tomatoKetchup
Hello,
According to the Nyx's manual it is possible to polychain several Nyx together, but there's absolutely no info or demo on the Internet. As anyone tried it?
Also I was reflecting on such a setup and thought of something even more amazing. It may be possible to create a stereophonic version of a 2-voice PolyNyx (name patent pending... smile ). This is all thought experiment and needs to be tested (someone with 2 Nyx out there?).
Here's how: the Nyx has an input jack at the back, but funnily enough it also doubles as a dry output (reverb bypassed). With that in mind:
Now that's nice in theory, but where it bugs me is that, likewise, the Nyx 2 dry out should also send its own sound to Nyx 1 through the same (grey) cable, and I doubt that one single unbalanced cable can carry signal in 2 directions at once.
Anyone knows what would be the result of this setup? Or even better, does anyone have access to 2 Nyx and can test it out?
IR
Seems like a pretty dumb idea, you'd only get the effect on the first two oscillators, so when you play chords you'd only get the two lower notes effected.
If you're into that you might as well turn the mix all the way up on the reverb.
The normal way would be to just use the effect on the last one in mono.
I bet you don't really need another Nyx, you could probably chain it to an Erebus as well.
SingIt
I have been looking around for this synth and can’t track one down. Seems like its all about the Erebus now.
tomatoKetchup
Well, in theory, Nyx 2 would also send its analogue signal through its dry OUT and into Nyx 1 IN (grey arrow in reverse), resulting in a similar effect as Nyx 1.
In practice I imagine physical world limitations would result in the signal being only allowed to go one way, so the end result is more likely that Nyx 2 voice will not travel into Nyx 1 and will thus only be heard in the R channel (albeit still effected by its own reverb section).
Still quite curious to try it out. And if that's indeed not possible, you could replace the 2nd Nyx by the WL Splash euro module, but losing the 4-voice paraphony along the way unfortunately. :(
IR
Who made up the theory, some random dude on a forum? I looked in the manual and it says to use a mono TS jack on both the input and output, which would exclude the possibility of that.
Nor does the diagram in the manual show any kind of output before the reverb. Nor could I find anything about the input being used as an output in the manual, can you tell me what page to look at?
tomatoKetchup
True, there's no documentation whatsoever about that. But it's proved and tested (by Nick Batt and then by myself). Maybe that wasn't intended by Dreadbox, maybe it could be some sort of a leakage of the signal. Might contact Dreadbox about that to find out actually.
Josef_K
Bumping this thread to hear if anyone's polychaining their Nyx(s)? No demo in sight but maybe someone has tried it? I'm curious if a 4x Nyx v2 setup is my dream 24db four voice. I mean per-voice reverb is pretty dumb, right? And separate glide control... Eh. But it seems to beat 4x Nyborg 24 since you can have global oscillators and in general lots of complex patching. If the Nyx has polychain implemented the manual should mention this, which it doesn't unless I'm blind. So I guess I'd need an event processor plus.
