Module that can determine tempo from a series of pulses?
Author Module that can determine tempo from a series of pulses?
mritenburg
Is there a Eurorack module that you feed a constant series of pulses and it will read out the bpm to a numeric display?
whinger
Pamela's New Workout can do that, that's how I clock mine.
cg_funk
The OTool+ also has a BPM counter, among other things.
EternalTurtle
Ornament and Crime can do it in references mode
starthief
Teletype can tell you milliseconds between pulses and convert to BPM (among a million other things).
Todai
Jones O'tool +
redonyellow
This. PNW can do that.
Blicken Synths
I tried sending the make noise pulse out of my octatrack to sync the clock of my eloquencer but it the eloquencer was really inconsistent
vidret
depends on how exact you need it to be, lots of modules 'latch' onto a trigger input and set their clocks to match.
the ones mentioned above, tempi does it too. tyme sefari mk2 too, now that I think about it, although it's obviously not the one to get for this job.
MalteSteiner
the Intellijel Metropolis sequencer does that too
batch
And the Erica Drum Sequencer
magneteyez
Can you elaborate on this?
StateAzure
O_c can do this..at least mine can (Hemisphere installed).
ggillon
edit: nevermind
