is the rolzer worth it?
MUFF WIGGLER Forum Index -> Ciat-Lonbarde
Author is the rolzer worth it?
odditymedium
those of you who have the rolzer, is it worth it?
despite my deep appreciation of peter's thinking behind the rolzer, which later led to the tocante scale, i wonder if it is worth the money?
i'm asking cos i'm thinking of getting one...
sungja
Have no experience with the rolzer but i believe it was meant to sound more like the rollz5 paper circuit. Why not start with building some of these and go from there?
odditymedium
as i have a plumbutter, it has some rollz as is: two 3-rollz and two 4-rollz.
i'm interested in hearing from rolzer owners whether such an expensive piece of gear that makes no sounds by itself (i mean, not really), is worth the investment
knows
You cannot voltage control the rollz as on the plumbutter. You can make more complex rhythms and control voltages and audio (to filter) and more of them, sharing browns or not.
You can set up unrelated clusters of connected browns and send to the plumbutter for weird drum patterns. Great to patch through the ultasound filters (brown). You can use it to control sequences and trigger other timing events (orange). I kind of think of it as big clock source that when you speed it up or interfere the browns, produces control and audio patterns.
I am sure some others have different ideas and ways they use it.
odditymedium
thanks knows. do you recommend buying one? would you buy one again?
knows
I still have one as part of my duosk. It is pretty awesome when I get a bunch of the browns interconnected and send it’s signals as audio and cv into both sets of the plumbutters ultrasounds. It does weird things with the man with red steam as well.
Would I buy it again? I don’t know.
If someone wanted to make the plumbutter into a more poly rhythmic *edit weird* drum machine, it would be great! I would give up any of the ciat lonbarde instruments for the Hordijk system.
jimmie
you can get more messy by interconnecting PB's roll to rolzer nanners
ClausF
As an addition to Plumbutter yes (if you have the Coco).
And as an own instrument, for some strange electronic noises, you have to build some attenuators for that. Just check the Rollz-5 PDF to get an idea how to connect the rolls. Works pretty well...
Like sungja I also recommend to build a few of the rolls from this document and experiment. Rolls are the simplest circuits there and you can have a lot of fun alone with them. Also experiment with different or switchable caps (in one roll)... I have this still nailed on a piece of wood, waiting for housing, but after a while experimenting and playing with the plumbutter patch on Shbobo I got lost and bought a Plumbutter, Coco, Rollzer and more... Rockin' Banana!
rmro
Not being a DIY expert. Could you buy a Rollz5 Meng Qi pcb and just solder the Rollz without the AV Dog, Gong & Ultrasound? Wonder if it would work to get some extra Rollz for the PB?
corpusjonsey
This will definitely work.
jimmie
JFY I'm still drifting to sell or unsell my Rollz5 hihi
sungja
When i think more about it building the rollz section in seven different values on paper is something worth trying out some day. It could be a cheap alternative for the rolzer.
odditymedium
i know pugix has listed the 2-roll here: http://pugix.com/synth/rollz-5-schematics/
any where else i can find 3, 4, 5, 6, 7-roll schematics?
or am i totally wrong, and there only 2,3,4 -rollz?
ClausF
In the Rollzer and Rollz-5 there are 3,4,5 & 6 rolls. There is no schematics, but you can extract it from the paper circuit, there are only around 5 parts/section.
Paper circuits and description is here: http://ciat-lonbarde.net/rollz5/
