debugging Human Comparator SY-1
Author debugging Human Comparator SY-1
ekoch
Hi I just finished an SY-1 build. Everything seems to be working except the VCAs seem to hang open, the envelope isn't closing either of them. Also the output from both channels seems low. I have identical problem on both channels so wonder if maybe it is not a wrong part (colleague order the parts...i had a bunch leftover so I suspect he may have used an old BOM). Any tips on where to look would be appreciated.
diophantine
I'd suggest looking & posting in the build thread:
https://www.muffwiggler.com/forum/viewtopic.php?t=163727
I'm not sure if the current run is different than the original run, so make sure to mention which you have.
cygmu
Your symptoms sound a bit like what happens when the power supply isn't working properly on the new version.
https://www.muffwiggler.com/forum/viewtopic.php?p=2825128#2825128
The solution there was to rework the power circuitry a little, undoing a "fix" that was introduced in this version.
https://www.muffwiggler.com/forum/viewtopic.php?p=2830114#2830114
If you haven't done that already, maybe it's worth a try.
sduck
Please use the build thread instead of creating separate threads - https://www.muffwiggler.com/forum/viewtopic.php?t=163727
