Replacing PSU2 with PSU3 in Doepfer Case
Author Replacing PSU2 with PSU3 in Doepfer Case
charlie360x
Hi, I have a Doepfer A-100 LC6 case with PSU3 and I recently purchased Doepfer A-100P6 Case with PSU2 (both 6u). Can I replace PSU2 from my new portable A-100P6 case with PSU3 from my low cost case? And if yes, what's the best way to do it? Can I just unscrew everything and swap places or I need to solder/unsolder anything?
Navs
Ask Doepfer directly: hardware (ät) doepfer (döt) de
There are some pictures of the old and new PSU here:
http://www.doepfer.de/a100_cases_d.htm
They look similar - at least the bus bars - but maybe the PSU3 is slightly wider and might need new holes to be drilled. hmmm.....
But ask Dieter thumbs up
andybizarre
This is a drop-in replacement, you can just switch the PSUs and use the same holes & screws. But beware of touching things on the PSU2 after removing the cover! Just make sure to follow all instructions and WARNINGS! as there`s (deadly) mains voltage inside.
There have been revisions of the Doepfer Busboard which didn`t offer 5V. If your P6`s busboards don`t have 5V connectors, you`ll have to switch them, too.
Take care!
