Unable to access delay parameters on my disting (solved)
Author Unable to access delay parameters on my disting (solved)
Parseq
When I select program B4, C3 or C4, I cannot change the parameter. Onlu the default is availbale. All other program work fine.
I have this issue on my two disting (v4.9).
gimber
Sounds like you may have missed the same part of the manual that I did:
https://www.muffwiggler.com/forum/viewtopic.php?p=2908830#2908830
Parseq
Indeed. I missed this part.
Thank you.
