Fh-2 MIDI Gate gets stuck
MUFF WIGGLER Forum Index -> Expert Sleepers Goto page Previous  1, 2 [all]
Author Fh-2 MIDI Gate gets stuck
Tonemod
Sorry, disregard.
AlexKemp
Hi there, so what's strange is that in the configurator I'm not seeing that sneaky run stop command that's causing the gate to open... see attached pdf of the config. Perhaps I'm missing something?
Most likely the sysex you posted doesn't actually correspond to this config. How did you capture it?
AlexKemp
I hit "upload from FH-2" on the chrome configurator page. I have this saved as a configuration (versus a preset) so I don't know if that's making a difference.
Here's another sysex dump created the same way
thank you!
8:45:32 AM
F0 00 21 27 2F 10 00 00 05 00 00 00 31 20 70 6F
6C 79 20 2F 20 32 20 6D 6F 6E 6F 20 00 32 00 01
18 00 00 00 01 00 01 00 01 00 01 00 01 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 01 00 00 7F 01 04 0C 00 00 00 00 00
01 0F 00 00 01 01 00 00 00 00 00 00 00 00 00 00
00 00 00 00 01 01 00 7F 00 01 0C 00 00 00 01 08
01 0F 00 00 01 01 01 00 00 00 00 00 00 00 00 00
00 00 00 00 00 02 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 03 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 04 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 05 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 06 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 07 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 08 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 09 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 0A 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 0B 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 0C 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 0D 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 0E 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 00 0F 00 7F 00 01 02 00 00 00 00 00
00 00 00 00 30 00 00 00 30 01 00 01 30 02 00 02
30 03 00 03 30 04 00 04 30 05 00 05 30 06 00 06
30 07 00 07 7F 00 00 00 7F 00 00 00 7F 00 00 00
7F 00 00 00 7F 00 00 00 7F 00 00 00 7F 00 00 00
7F 00 00 00 00 60 01 00 00 00 00 00 00 18 01 00
01 00 00 00 00 01 01 00 02 00 00 00 00 01 01 00
03 00 00 00 00 01 01 00 04 00 00 00 00 01 01 00
05 00 00 00 01 60 01 00 46 00 00 00 01 18 01 00
47 00 00 00 00 01 01 00 08 00 00 00 00 01 01 00
09 00 00 00 00 01 01 00 0A 00 00 00 00 01 01 00
0B 00 00 00 00 01 01 00 0C 00 00 00 00 01 01 00
0D 00 00 00 00 01 01 00 0E 00 00 00 00 01 01 00
0F 00 00 00 00 01 01 00 10 00 00 00 00 01 01 00
11 00 00 00 00 01 01 00 12 00 00 00 00 01 01 00
13 00 00 00 00 01 01 00 14 00 00 00 00 01 01 00
15 00 00 00 00 01 01 00 16 00 00 00 00 01 01 00
17 00 00 00 00 01 01 00 18 00 00 00 00 01 01 00
19 00 00 00 00 01 01 00 1A 00 00 00 00 01 01 00
1B 00 00 00 00 01 01 00 1C 00 00 00 00 01 01 00
1D 00 00 00 00 01 01 00 1E 00 00 00 00 01 01 00
1F 00 00 00 00 00 00 40 00 00 00 40 00 00 00 40
00 00 00 40 00 00 00 40 00 00 00 40 00 00 00 40
00 00 00 40 00 00 00 00 00 00 00 01 00 00 00 02
00 00 00 03 00 00 00 04 00 00 00 05 00 00 00 06
00 00 00 07 00 00 00 08 00 00 00 09 00 00 00 0A
00 00 00 0B 00 00 00 0C 00 00 00 0D 00 00 00 0E
00 00 00 0F 00 00 00 10 00 00 00 11 00 00 00 12
00 00 00 13 00 00 00 14 00 00 00 15 00 00 00 16
00 00 00 17 00 00 00 18 00 00 00 19 00 00 00 1A
00 00 00 1B 00 00 00 1C 00 00 00 1D 00 00 00 1E
00 00 00 1F 00 01 02 03 04 05 06 07 08 09 0A 0B
0C 0D 0E 0F 00 01 00 4D 00 00 00 00 7F 7F 7F 7F
7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 14 00 10 00
00 00 00 00 15 01 70 7F 00 20 00 00 16 02 10 00
00 00 00 00 19 03 70 7F 00 20 00 00 17 04 08 00
00 10 00 00 18 05 08 00 00 10 00 00 05 06 00 00
00 00 00 00 06 07 00 00 00 00 00 00 1E 08 00 00
00 00 00 00 1F 09 00 00 00 00 00 00 20 0A 00 00
00 00 00 00 21 0B 00 00 00 00 00 00 01 0C 00 00
00 00 00 00 02 0D 00 00 00 00 00 00 03 0E 00 00
00 00 00 00 04 0F 00 00 00 00 00 00 07 10 00 00
00 00 00 00 08 11 00 00 00 00 00 00 09 12 00 00
00 00 00 00 0A 13 00 00 00 00 00 00 0B 14 00 00
00 00 00 00 0C 15 00 00 00 00 00 00 0D 16 00 00
00 00 00 00 0E 17 00 00 00 00 00 00 00 18 00 00
00 00 00 00 00 19 00 00 00 00 00 00 00 1A 00 00
00 00 00 00 00 1B 00 00 00 00 00 00 00 1C 00 00
00 00 00 00 00 1D 00 00 00 00 00 00 00 1E 00 00
00 00 00 00 00 1F 00 00 00 00 00 00 01 00 1E 00
00 00 00 40 01 01 1F 00 00 00 00 40 01 02 20 00
00 00 00 40 01 03 21 00 00 00 00 40 01 04 22 00
00 00 00 40 01 05 23 00 00 00 00 40 01 06 24 00
00 00 00 40 01 07 25 00 00 00 00 40 00 08 04 00
00 00 00 40 00 09 05 00 00 00 00 40 00 0A 06 00
00 00 00 40 00 0B 07 00 00 00 00 40 00 0C 08 00
00 00 00 40 00 0D 09 00 00 00 00 40 00 0E 0A 00
00 00 00 40 00 0F 0B 00 00 00 00 40 00 10 0C 00
00 00 00 40 00 11 0D 00 00 00 00 40 00 12 0E 00
00 00 00 40 00 13 0F 00 00 00 00 40 00 14 10 00
00 00 00 40 00 15 11 00 00 00 00 40 00 16 12 00
00 00 00 40 00 17 13 00 00 00 00 40 00 18 14 00
00 00 00 40 00 19 15 00 00 00 00 40 00 1A 16 00
00 00 00 40 00 1B 17 00 00 00 00 40 00 1C 18 00
00 00 00 40 00 1D 19 00 00 00 00 40 00 1E 1A 00
00 00 00 40 00 1F 1B 00 00 00 00 40 00 00 00 00
00 00 00 00 00 00 00 00 01 01 01 01 01 01 01 01
01 01 01 01 01 01 01 01 F7
OK, loading that, I get this - is that right?
AlexKemp
Yes, that's also what I'm seeing! Its a preset set up for 4 voice poly on the Fh-2 and 1 voice mono on the expander, plus two clocks
And this has the odd gate on output 8 still?
AlexKemp
yes, it does. I've even reinstalled the firmware and started from scratch with an init configuration.
The initial configuration does have the run/stop on output 8. You'll need to go in and remove that if you don't want it.
I just tried your sysex on my FH-2 and it works fine - no gate on output 8 when starting the transport.
av500
Os, not sure if you saw that the latest Keystep Firmware mentions this bugfix:
...USB packets now properly sent, solves the connection to a USB host such as the FH-2...
Ah, good news, they released it. Thanks.
av500
os wrote:
Ah, good news, they finally released it. Thanks.
since I am also fighting Arturia USB bugs with in combination with embedded USB hosts, do you know what was actually wrong?
I can give you a name at Arturia if you want to speak to them. Email me.
av500
thanks, will do applause
Seaweed Sound
So glad Arturia finally fixed this
progenitor
Just saw the Arturia email as well and ran out to look up the bug fixes and was ecstatic to see the FH-2 issue mentioned. I’m still jamming the FH-1 and love it. It’s finally time to plug the Keystep back in! Thank you for bugging them about it ;D
Page 2 of 2
