If a filter is a slew - then also a kind of LPG/VCA?
boxxgrooved
Post by boxxgrooved » Mon Jan 28, 2019 6:52 am
According to Ken Stone's description of the VCS:
"If an audio rate signal is slewed, the module responds like a VCF, and a rough VCA. The signal is low-pass filtered down to silence, similar to a low-pass gate."
When he says 'similar to a LPG' I presume he is referring to the fact a LPG also attenuates the signal along with filtering it?
A low-pass filter will also bring a signal down to silence so it got me thinking about using my filters as crude vca's when in a pinch. Its not something I have experimented with before and I'm away at the moment so I can't try it out. Would using a filter with a lower pole sound more natural?
SB-SIX
Post by SB-SIX » Mon Jan 28, 2019 8:59 am
It depends on the filter. Some filters close entirely very easy, others are still audible even when fully closed. Setting the resonance to the lowest will make it sound more like a VCA, but of course it looses the high frequencies first (on an LPF)
There is a chance you might like this: https://soundcloud.com/steeboo
boxxgrooved
Post by boxxgrooved » Mon Jan 28, 2019 12:22 pm
Yeah I think resonance is to be avoided and I also think 6/db filter would sound more natural but I don't have any of those.
gruebleengourd
Post by gruebleengourd » Mon Feb 04, 2019 5:08 pm
boxxgrooved wrote:Yeah I think resonance is to be avoided and I also think 6/db filter would sound more natural but I don't have any of those.
FWIW a slew generator typically IS a 6 db low pass filter.
