digital noise, 500 serie interferance with ES-3 and ES-6
Author digital noise, 500 serie interferance with ES-3 and ES-6
Jaypee
Hello there smile I've been using ES-3 and ES-6 with a USBStreamer ADAT interface for 2 years now and never solved this problem:
let's say I want to use my 500 serie chain to process a stem in my DAW.
ES-3 out->500 serie->ES-6.
But, when I plug a cable into my ES-3 or/and ES-6, some digital noise appears on my speakers.
I can still record. No noise on the recordings! (If I unplugged my 500 serie after recording, and listen the recordings I have no noise)
So I assume there is a problem between the speakers and the ES-3/ADAT?
I highly suspect that ADAT interface.
Problem appears even if the 500 serie is turned off (but still plugged into ES-3/ES-6 ofc).
Before this setup I used a Lyra Prism and didn't have this problem, could still use my 500 serie with no noise. So I don't think the problem come from here.
Any ideas? tests to do?
Cheers!
J.
How is your modular powered? Sounds like a classic ground loop problem to me.
Jaypee
Tiptop Mantis
So I guess you're using a switching power supply with that?
Have you tried a DI box in the signal chain to break the ground loop?
Jaypee
Yes, a switching power, that one that came with Mantis.
No...I haven't tried that...
I use this 500 serie box: https://www.thomann.de/fr/fredenstein_bento_6s.htm
that has this:
but it doesn't change anything when I ON/OFF it.
Can you recommend me a DI box I could buy to try?
Are you sure it's not coming from UsbStreamer?
I will try to disconnect it today
Many thanks!
I don't have a recommendation for a DI box, sorry.
The joy of ADAT is that it's optical - there's no way an ADAT connection can introduce a ground loop.
Jaypee
Ok, thanks, I will investigate and check which DI box I can buy!
Multi Grooves
I just got a pair of hs7s
