Choices, IMP, and Plague Bearer Kits available.
Gear, Suggestions and Discussion.
Moderators: Kent, computer controlled, flight
flight
The Plague Bearer
Post by flight » Wed Jan 30, 2019 10:30 pm
Hey everyone,
DIY kit versions of the Choices, IMP, and Plague Bearer eurorack modules are either in stock at or on their way to Modular Addict and Thonk Ltd.
Kit versions vs. module versions:
  • CH-K: Choices kit v1.0 is made from the Choices v2.0 module.
  • IMP-K: IMP kit v1.0 is made from the IMP v1.0 module.
  • PB-K: Plague Bearer kit v2.0 is made from the Plague Bearer v4.0 module.
All kits are redesigned from the modules to allow for easier soldering and assembly with:
  • wider spacing between components
  • increased solder pad sizes
  • any abnormally delicate surface mount components replaced with through-hole components
Manuals:
Choices Kit
IMP Kit
Plague Bearer Kit
(I forgot to take pictures of the Plague Bearer kit, sorry.)
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
Waz
Wiggling with Scurvy
Post by Waz » Sun Mar 24, 2019 10:40 pm
What are the chances of the SoS becoming a DIY kit?
mamonu
90s ambient miscreant!!
Re: Choices, IMP, and Plague Bearer Kits available.
Post by mamonu » Sun Jan 19, 2020 8:42 pm
is there any chance of getting the fpd file for IMP in frac format.
Or any other kind of design file to that effect?
frac & 100m & eurorack (equal opportunities wiggler)
:blacet: :blacet: fracmodular.github.io :blacet: :blacet:
flight
The Plague Bearer
Re:
Post by flight » Sun Jan 19, 2020 11:35 pm
Sorry I never got around to replying to this, but they are available now at MA and Thonk.
~flight
flight
The Plague Bearer
Post by flight » Sun Jan 19, 2020 11:36 pm
I can make you one in pdf format, will that work?
~flight
mamonu
Post by mamonu » Mon Jan 20, 2020 2:22 pm
yes it would.
although a vector format would work a bit better (AI,DWF).
but... beggars cannot be choosers and i thank you for any help on this.
In the absence of other things PDF is fine.
flight
The Plague Bearer
Post by flight » Tue Jan 21, 2020 11:04 pm
yes it would.
Okiedokie, .ai it is then. Attached.
IMP-K Frac.ai
(466.3 KiB) Downloaded 10 times
~flight
mamonu
Post by mamonu » Fri Jan 24, 2020 10:24 pm
:yay: :tu:
thanks !
Return to “Flight of Harmony”
