FH-2 and Octatrack
Author FH-2 and Octatrack
henrry
Hi every body.
I just got the FH-2 but it looks like I can't get it to do what I thought would be easy as pie:
Namely, trying to allocate different midi tracks from the octatrack to different outputs on the FH-2 in order to play diffrent monophonic voices on the modular This is fun!
But no way to do that!
All the channels go to the same outputs
MY ASS IS BLEEDING
First I thought I did the configuration wrong and tried different options but with no good result.
Then I imagined it was an issue with the cable I use to connect the Octatrack to the FH-2: the MIDIMATE eX.
At first I was confident because I did get feedback messages from the FH-2 that it gets correctly the played notes on the configured MIDI channels.
My configuration is the following:
- Channel 9 to Minitaur. No problem
- Ch. 10 with CV, gate, velocity On outputs 1,2,3: No problem
- Ch. 11 with CV, gate, velocity On outputs 5,6,7: Plays on 1,2,3
- Ch. 12 with gate on output 4: plays on output 1
- CH. 13 with gate on output 8: .... Stoped testing at this point.
Then to I verified using Ableton live to see if the problem actually came from my cable. So I connected my computer to the FH-2 using the USB-C cable:
Same result. Dead Banana
Here is a picture of my setup in the editor:
Does anybody know what's wrong?
I'can't imagine that this feature may be impossible to implement at this point.
Cheers.
henrry
hmmm.....
Actually I did forget to configure the "Base Output" according to the actual outputs on the FH-2.
So now I can tell: MIDIMATE eX, Octatrack and FH-2 work together as a charm
Rockin' Banana!
