Feature Request: LFO delay
Author Feature Request: LFO delay
miminashi
I'm applying a fair amount of negative delay to the MIDI clock when syncing external sequencers to get my outboard gear lining up in time with the pre-recorded tracks in Cubase. Since the LFO signal is rendered at the outputs in time with 'regular' audio, it runs a bit late relative to my sync'd devices. I would like them to have the same notion of time as the MIDI clock, which means having them run ~10ms ahead of Cubase's transport.
Would it be possible to add +/- delay to the LFO plugins, as featured on the Sync plugin?
Thanks, I've noted the suggestion.
miminashi
Thanks, os.
